제품 정보로 건너뛰기
1 3
Kawasaki Plug & Play AiM Taipan Motocross ECU Kit
SKU: C-EUC-KIT-KAW
정가
£635.00
정가
세일 가격
£635.00
Shopify Planet을 통한 탄소 중립 배송
모든 주문에 대해 탄소 중립 배송
AiM Taipan ECU Plug & Play Kit For Kawasaki Motocross Bikes
Traction Control
Traction Control Strategy
Launch Control
High Technology 32-bit Core
Engine control requires precision. At 20,000 RPM the Taipan ECU guarantees a precision of 1/10 of degree: this means an accuracy within 0.8 sec for turning the spark ON!
UC Bridge
Tuner License :
Taipan ECU Connections
Aim Handlebar Switch
Below shows a functional diagram of products that can be added to the Taipan ECU:
AiM Taipan ECU Plug & Play Kit for Kawasaki
  • One low side driver (1 A)
  • Power consumption 150 mA
  • n. 1 33 pin male Connector
  • Body: PA6 + 30% glass fiber
  • Waterproof: IP67
  • Weight: 260g
  • Plug & Play ECU for Kawasaki
Traction Control
Launch Control
UC Bridge
Tuner License :
  • Waterproof: IP67
  • Weight: 260g
Video
