제품 정보로 건너뛰기
1 1
AiM Water/Oil Temperature Sensor PT100 M5 Thermo Resistor
SKU: S-T-M5
정가
£70.00
정가
세일 가격
£70.00
+ VAT(영국만 해당)
Shopify Planet을 통한 탄소 중립 배송
모든 배송은 탄소 중립적입니다.
Powered by Shopify Planet
The AiM PT100 M5 Thermo resistor temperature sensor is suitable for reading water and oil temperatures.
Suitable for water/oil temperature 4 pins 719 male binder
PT100 - M5
Sensor cable length 25cm
  • Temperature working range: 0/150°C
  • Cable sensor length: 250mm
  • M5 Thermo resistor
  • 4 pins male 719 Binder connection
  • 2kΩ 1% resistor between pins 1 and 4
  • AiM Water/Oil Temperature Sensor M5 Thermo Resistor
PT100 - M5
