Ducati Panigale 899, 959, 1199, 1199R, 1299 AiM Solo 2 DL & EVO4S Logger Plug & Play Cable
SKU: DUC-PP
- 정가
- £67.00
- 정가
- 세일 가격
- £67.00
- 단가
- 당
Ducati Panigale 899, 959, 1199, 1199R, 1299 AiM Solo 2 DL & EVO4S Plug & Play Cable
The AiM ECU plug & play cable has been specifically designed for Ducati Panigale bikes. Allowing easy installation to a Solo 2 DL and EVO4S Data Logger. With a 7-pin 712 male binder connection.
Ducati Panigale plug & play cable | 7 pin - 712 male binder connection |
Receive data | Suitable for Solo 2 DL & EVO4S Data Logger |
Ducati Panigale Plug & Play ECU Cable
The AiM ECU plug & play cable has been specifically designed for the Ducati Panigale bike. This plug & play cable can be used for the Solo 2 DL and EVO4S Data Logger.
The plug & play cable currently fits the following Ducati Panigale bike models:
899 Panigale - 2013-2015 | 959 Panigale - From 2016 |
1199 Panigale - 2012-2014 | 1199R Panigale - 2015-2017 |
1299 Panigale - 2015-2019 |
Example data protocols
- Below is a pinout drawing for the Ducati Panigale 899, 959, 1199, 1199R, 1299 plug & play connection cable
- Ducati Panigale 899, 959, 1199, 1199R, 1299 Plug & Play connection cable
The AiM ECU plug & play cable has been specifically designed for Ducati Panigale bikes. Allowing easy installation to a Solo 2 DL and EVO4S Data Logger. With a 7-pin 712 male binder connection.Key Features :
The AiM ECU plug & play cable has been specifically designed for the Ducati Panigale bike. This plug & play cable can be used for the Solo 2 DL and EVO4S Data Logger.The cable is an easy fitment to your bike and allows ECU data to be logged.
These are some of the items that can be added to your bike for incrementing performance and data. ![]() |
