제품 정보로 건너뛰기
1 4
Honda CBR 600RR/1000RR Solo 2 DL Plug & Play Lap Timer Kit
SKU: SOLO2-K-HON
정가
£710.00
정가
세일 가격
£710.00
+ VAT(영국만 해당)
Shopify Planet을 통한 탄소 중립 배송
모든 주문에 대해 탄소 중립 배송
Powered by Shopify Planet
Honda CBR 600RR & 1000RR AiM Solo 2 DL Plug & Play Lap Timer Kit
AiM Solo 2 DL is the most precise and simple way to get lap times. Specifically designed for the Honda, this kit will ensure an improvement in your driving performance.
Database with more than 4,000 tracks worldwide Honda ECU connection cable
This kit has been specifically designed for Honda bikes. The kit comes with a cable and bracket for your bike. Connecting the Solo 2 DL to your Honda ECU will give you all the engine performance information you need to help improve your driving performance.
CBR 600RR - 2003-2019 CBR 600RR HRC with D11 marked ECU - 2013-2015
CBR 1000RR - 2004-2016 CBR 1000RR HRC - 2014-2016
Please Note: The bracket is only compatible with CBR 600RR original triple plate.
The Honda ECU interface cable provides a plug & play solution for connecting the Solo 2 DL lap timmer to your bike. Please refer to the technical sheet on how to connect the ECU cable to your bike.
Data Recall On Screen
  • Display: Graphical
  • Wi-Fi connection: Yes
  • GPS: 10 Hz
  • External power: 12 V
  • Memory: 4 GB
  • Pushbuttons: Metallic
  • Waterproof: IP67
Below is the pinout drawing for the Honda 600RR, 1000RR plug & play connection cable.
  • Solo 2 DL
  • Power cable with AC adapter
  • User manual
  • AiM Honda Connection Cable
  • Bracket
  • 1 washer
  • 1 Allen screw with rounded head M6 x 60
  • 1 rubber dowel
  • GPS: 10 Hz
  • Memory: 4 GB
  • Waterproof: IP67
  • Solo 2 DL
  • User manual
  • Bracket
  • 1 washer
  • 1 rubber dowel
