Kawasaki ZX-10R AiM Solo 2 DL & EVO4S Logger Plug & Play Cable
SKU: KAW-PP
- 정가
- £67.00
- 정가
- 세일 가격
- £67.00
- 단가
- 당
+ VAT(영국만 해당)
Kawasaki ZX-10R AiM Solo 2 DL & EVO4S Plug & Play Cable
The AiM ECU plug & play cable has been specifically designed for Kawasaki bikes. Allowing easy installation to a Solo 2 DL and EVO4S Data Logger. With a 7-pin 712 male binder connection.
Kawasaki plug & play cable | 7 pin - 712 male binder connection |
Receive data | Suitable for Solo 2 DL & EVO4S Data Logger |
Kawasaki Plug & Play ECU Cable
The AiM ECU plug & play cable has been specifically designed for the Kawasaki bike. This plug & play cable can be used for the Solo 2 DL and the EVO4S Data Logger.
The plug & play cable currently fits the following Kawasaki bike models:
Kawasaki Ninja ZX-10R MY2011 - 2001-2015 | Kawasaki Ninja ZX-10R MY2011 Racing Kit - 2011-2015 |
Example data protocols
- Below is a pinout drawing for the Kawasaki ZX-10R Solo 2 DL & EVO4S Data Logger plug & play connection cable
- Kawasaki ZX-10R Plug & Play connection cable
The AiM ECU plug & play cable has been specifically designed for Kawasaki bikes. Allowing easy installation to a Solo 2 DL and EVO4S Data Logger. With a 7-pin 712 male binder connection.Key Features :
The AiM ECU plug & play cable has been specifically designed for the Kawasaki bike. This plug & play cable can be used for the Solo 2 DL and the EVO4S Data Logger.The cable is an easy fitment to your bike and allows ECU data to be logged.
The plug & play cable currently fits the following Kawasaki bike models:Kawasaki Ninja ZX-10R MY2011 - 2001-2015 | Kawasaki Ninja ZX-10R MY2011 Racing Kit - 2011-2015 |
