Link CAN PCB Cable
SKU: CANPCB
- 정가
- £28.00
- 정가
- 세일 가격
- £28.00
- 단가
- 당
Link CAN PCB Cable
Cable (CANPCB)
Required to add CAN/Serial communications to G4+/G4X Plugin ECU’s. Plugs directly into ECU PCB header. Use the Link CANF connector (purchased separately) to connect.
Link CAN PCB Cable
- CAN to JST Connector
- 200mm
Link CAN PCB Cable
Cable (CANPCB)Required to add CAN/Serial communications to G4+/G4X Plugin ECU’s. Plugs directly into ECU PCB header. Use the Link CANF connector (purchased separately) to connect.
Link CAN PCB Cable
- 200mm
