Link G4 KnockLink Kit - Includes Knock Sensor & Loom
SKU: G4KNLK
- 정가
- £225.00
- 정가
- 세일 가격
- £225.00
- 단가
- 당
+ VAT(영국만 해당)
The G4+ KnockBlock is an essential tool for tuning and can aid in the early detection of incorrect ignition timing, lean air/fuel mixtures and mechanical issues. It is used with earbuds, headphones or noise-cancelling earmuffs and features special filtering to allow you to listen in and detect knock early.
Simple Operation
The colour of the LED represents four different modes:
Dim Blue - KnockLink is powered, waiting for the engine to be started
Flashing Blue - KnockLink has detected the engine has started and is now calibrating
Dim Green - KnockLink is adapting to the engine's noise profile and listening for knock
Flashing Red - KnockLink has detected knock. Avoid large throttle openings, seek professional advice
- Knock Sensor
- Loom
The G4+ KnockBlock is an essential tool for tuning and can aid in the early detection of incorrect ignition timing, lean air/fuel mixtures and mechanical issues. It is used with earbuds, headphones or noise-cancelling earmuffs and features special filtering to allow you to listen in and detect knock early.Simple Operation
The colour of the LED represents four different modes:Dim Blue - KnockLink is powered, waiting for the engine to be started
- Knock Sensor
- Loom
