제품 정보로 건너뛰기
1 4
Link Nissan S13Link - NS13X PlugIn ECU
SKU: NS13X
정가
£1,475.00
정가
세일 가격
£1,475.00
Shopify Planet을 통한 탄소 중립 배송
모든 주문에 대해 탄소 중립 배송
Designed for the SR20 and CA18 engines, that use the 76 pin Blue ECU Header.
It includes an onboard 4 bar or 7 bar MAP sensor.
Suitable Applications:
Nissan S13 CA18DET
Nissan 180SX CA18DET
Nissan S14 (pre-facelift) SR20DET
PlugIn Key Features:
Sequential fuel delivery
OEM idle hardware supported
CAN port
USB tuning cable included
Staged injection
Knock with "windowing"
I/O Expansion Options:
Expansion connector 1
Gnd Sensor Ground Only
DI 5 Digital Input
DI 6 Digital Input
DI 7 Digital Input
An Volt 6 Analog 0-5V input
Expansion connector 2
Ign 5 Ignition 5 Auxiliary Output
Volt 8 Analog 0-5V input
Volt 9 Analog 0-5V input
Volt 10 Analog 0-5V input
Volt 11 Analog 0-5V input
Link Nissan S13Link - NS13X ECU
  • G4X PlugIn ECU
  • Stickers
Nissan S13 CA18DET
CAN port
Staged injection
Expansion connector 1 Gnd Sensor Ground Only
DI 5 Digital Input
DI 6 Digital Input
DI 7 Digital Input
An Temp 3 Temperature sensor input Expansion connector 2  Ign 5 Ignition 5 Auxiliary Output
  • G4X PlugIn ECU
  • Stickers
