제품 정보로 건너뛰기
1 2
Link XS Expansion Loom #XSL
SKU: XSL
정가
£29.75
정가
£35.00
세일 가격
£29.75
Shopify Planet을 통한 탄소 중립 배송
모든 주문에 대해 탄소 중립 배송
Want to add additional inputs/output to your Link Plugin ECU? Use the XS Loom. The Link XS Loom plugs into the expansion connector on all Link G4, G4+ and G4X plug-in ECUs.
The number of extra inputs and outputs added by the XS Loom is dependent on the Plugin ECU. For specific details check the plug-in ECUs specifications.
Common applications include but are not limited to:
Boost adjustment knob or switch
Wide-band AFR/Lambda
Oil Pressure Sensor
Fuel Pressure Sensor
Inlet Air Temperature (IAT) sensor
Map switch (Different tunes available via toggle switch)
The XS Loom is 2.5m long and uses 20AWG wire.
  • XS Loom 2.5m
Want to add additional inputs/output to your Link Plugin ECU? Use the XS Loom. The Link XS Loom plugs into the expansion connector on all Link G4, G4+ and G4X plug-in ECUs. The number of extra inputs and outputs added by the XS Loom is dependent on the Plugin ECU. For specific details check the plug-in ECUs specifications.
Oil Pressure Sensor
  • XS Loom 2.5m
