Peugeot Sport 208 Rally4 Aim SmartyCam 3 Corsa Kit from 2020
SKU: peugeot-SM3
- 정가
- £1,150.00
- 정가
- 세일 가격
- £1,150.00
- 단가
- 당
Compact, Advanced, Precise
Enhance your Peugeot Sport 208 Rally4's performance with the AiM SmartyCam 3 Corsa Kit, specifically designed for models from 2020.
Supported Models and years
Peugeot Sport 208 Rally4from 2020
Peugeot Sport 208 Rally4 features a bus communication protocol based on CAN that can be reached through the 4 ways ITT Cannon female connector labelled GIP and located on the central tunnel.
Standalone Feature
The SmartyCam 3 Corsa provides you with a CAN expansion that connects with many Aim devices such as the Solo 2 DL Laptimer, various Aim Dash Display Loggers, and PDM Dash systems. This is a standard practice within our products, however we have also equipped the SmartyCam 3 Corsa with unterminated CAN connections which allow you to connect the camera to any system as a standalone feature. No matter your vehicle and equipment, with the unterminated connectors you can run the Corsa through your CAN/ECU connections.
Quality
Anatomy
Finished with a sleek new look, the SmartyCam 3 Corsa is assured to add efficiency, informational data, productivity, and style to your racing. AiM SmartyCam 3 Corsa allows you to connect ECU direct to your camera with b connectors. Here at AiM, we provide only the best innovations and are constantly and consistently working to better your racing experience.
Higher Storage Capacity
SD cards sold separately.
- CMOS sensor: Global Shutter
- Field of view: 67°, 84°
- External power: 9-15 Volt
- Connectors: 3 Binder 712 female 1 USB-C
- Auto Power ON: Yes
- Auto Power OFF: Yes
- Dimensions: 102.2 x 63 x 46.5 mm
- Weight: 280g, battery included
- Waterproof: IP65-rated to withstand the rigours of motorsport, this kit offers durability and reliability for Peugeot Sport 208 Rally4 drivers
Channels received by AiM devices configured with Peugeot Sport 208 Rally4 protocol are:
Channel Name | Function |
RPM | Engine RPM |
Car Speed | Vehicle Speed |
Wheel Speed FL | Wheel Speed front left |
Wheel Speed FR | Wheel speed front right |
Wheel Speed RL | Wheel speed rear left |
Wheel Speed RR | Wheel speed rear right |
rPedal | Throttle pedal position |
PBrake Front | Brake pressure front |
PBrake Rear | Brake pressure rear |
aSteering | Steering wheel angle |
Gear | Engaged gear |
Water Temp | Engine coolant temperature |
Oil Temp | Engine oil temperature |
Air Temp | Intake air temperature |
Ambient Temp | AMbient temperature |
Oil Press | Engine oil pressure |
Boost | Boost pressure |
- SmartyCam 3 Corsa
- USB-C Cable
2m CAN Cable
- 712 5 Pin Male
Standalone Feature
Quality
Anatomy
Technical Specifications
Peugeot Sport 208 Rally4 Protocol
RPM | Engine RPM |
What's In The Box
- SmartyCam 3 Corsa
- USB-C Cable
2m CAN Cable
- 712 5 Pin Male
