Remote Button CAN Interface Pro Keypad - 4, 6, 8, 10, 12 & 15 Key Keypads
SKU: RBI-B4-PRO
- 정가
- £240.00
- 정가
- 세일 가격
- £240.00
- 단가
- 당
+ VAT(영국만 해당)
12 KEY AND 15 KEY CAN KEYPADS SOLD FROM 14/06/2023 WILL USE V2 PROTOCOL
*Please be aware that our PRO Keypads will require a more complex configuration than our Standard CAN Keypads but will add more customisability and features. If you would like to use the easy configuration method built into Race Studio 3, you must buy our Standard CAN Keypad.
The remote button interface keypads will enable you to have your very own selected buttons at your fingertips. Available in 4, 6, 8,10,12 and 15 key keypads.
Configurable channels | Multicolour indicator rings |
CAN bus compatible keypad | LED status configurable |
LED-backlit icons | Vertical or horizontal mount |
CAN Interface Keypad
The AiM remote button CAN interface keypads will enable you to have your very own selected buttons at your fingertips. The keypads are designed to a high standard to the highest standards for the harshest motorsport conditions. The keypad can withstand the cleaning of pressure washers and holds an IP67 rating, making them immune to water, mud, soil, sand, oil, chemicals.
The Pro keypads are available in 4, 6, 8, 10,12,15
Easy to Read
The keypads feature bright LED indicators, making them easy to read in any situation. The multi-coloured LED status rings allow you to set specific colours to your requirements.
With an extensive range of laser-etched inserts available, you can customise your keypad the way that's right for you, Lights, Heating & Fans; parking, the list is endless.
Please Note:
The keypads come blank with no inserts. We have an extensive range available; see the optional extras at the top of the page. Also, the lights on the keypads are for visual effect to show you how the keypad could look.
4 Button Tech Sheet | 6 Button Tech Sheet | 8 Button Tech Sheet | 10 Button Tech Sheet | 12 Button Tech Sheet | 15 Button Tech Sheet |
User Guide | 12 WAY PRO V2 | 15 WAY PRO V2 |
- Remote Button CAN Interface Pro Keypad
12 KEY AND 15 KEY CAN KEYPADS SOLD FROM 14/06/2023 WILL USE V2 PROTOCOL*Please be aware that our PRO Keypads will require a more complex configuration than our Standard CAN Keypads but will add more customisability and features. If you would like to use the easy configuration method built into Race Studio 3, you must buy our Standard CAN Keypad.
The AiM remote button CAN interface keypads will enable you to have your very own selected buttons at your fingertips. The keypads are designed to a high standard to the highest standards for the harshest motorsport conditions. The keypad can withstand the cleaning of pressure washers and holds an IP67 rating, making them immune to water, mud, soil, sand, oil, chemicals.The Pro keypads are available in 4, 6, 8, 10,12,15
Easy to Read
The keypads feature bright LED indicators, making them easy to read in any situation. The multi-coloured LED status rings allow you to set specific colours to your requirements.With an extensive range of laser-etched inserts available, you can customise your keypad the way that's right for you, Lights, Heating & Fans; parking, the list is endless.
Please Note:
The keypads come blank with no inserts. We have an extensive range available; see the optional extras at the top of the page. Also, the lights on the keypads are for visual effect to show you how the keypad could look.Configure & Analyse with Race Studio 3
With Race Studio 3 you can also analyse all data recorded and downloaded to your PC: graphs, histograms and tables will help you study your performance, providing objective support to avoid mistakes and improve performances.Technical Specifications
Whats in The Box
4 Button CAN Protocol | 6 Button CAN Protocol | 8 Button CAN Protocol | 10 Button CAN Protocol | 12 Button CAN Protocol | 15 Button CAN Protocol | 12 Button CAN V2 Protocol | 15 button CAN V2 Protocol |
