제품 정보로 건너뛰기
1 5
Super B Andrena 12V10Ah Lithium Battery
SKU: SB-10
정가
£465.00
정가
세일 가격
£465.00
Shopify Planet을 통한 탄소 중립 배송
모든 주문에 대해 탄소 중립 배송
Light-weight, high-performance, safe and reliable lithium power battery, especially  developed for motorsports. This battery equals a lead-acid battery of 20 to 32Ah, provided the  alternator’s maximum current doesn’t exceed the battery’s maximum charge current of  37A. Designed in a standard rally casing. Suitable for 12V systems and for use in extreme  environments.
Lightweight Power
With a weight of only 1.7kg /3.7lbs, the Andrena 12V10Ah power battery saves up to 80% in weight in comparison to traditional lead-acid batteries and is only 1/3 of the size of a conventional battery. This improves not only the performance of your vehicle but also helps to increase the fuel economy.
The power battery offers a high level of power, fast charging and a long, maintenance-free service life. It also has a stable and flat discharge which means you have over 80% of the batteries capacity available and you can leave your vehicle unattended for a much longer period compared to a lead-acid battery.
Safe & Reliable
Super B batteries are based on lithium iron phosphate technology (LiFePO4). This is the safest lithium  technology available today. On top of that our bespoke casing and electronics further increase safety  and durability. Due to its high ingress protection class (IP69) the battery is completely dust tight and  waterproof . Therefore the battery can be used in the most extreme environment as well.
Performance
Fast charging
Lightweight
Compact size
Low self-discharge
High discharge rates
3 Year Warranty
ELECTRICAL SPECIFICATIONS
Nominal Capacity 10Ah
Energy 128Wh
Nominal Voltage 12.8V
Open Circuit Voltage 13.2V
Self Dischrage <3% per month
EqPb (Equals lead-acid)  20 to 32Ah
MECHANICAL SPECIFICATIONS
Dimensions (LxWxH) 120 x 82 x 124mm | 4.72” x 3.23” x 4.88”
Weight 1.7 kg / 3.7lbs
Case Material PC - ABS
Ingress Protection IP69
Charge Method CCCV
Charge Voltage 14.3V - 14.6V
Max Charge Current 37A
End of Discharge Voltage 8V
Discharge Current Continuous 160A
Discharge Pulse Current (1 sec) 493a (49C)
TEMPERATURE SPECIFICATIONS
COMPLIANCE SPECIFICATIONS
EAN-13 8718531360037
Battery Designation 4IFpR27/66-4
Lightweight Power
Safe & Reliable
Performance
Fast charging
Lightweight
Compact size
Low self-discharge
3 Year Warranty
Energy 128Wh
Charge Method CCCV
Data Sheet
Guide
User Manual
