Aim 37 Pin Deutsch Harness For MX Series
SKU: H37-V02...
£375.00£450.00INC VAT - UK only
- £375.00
The Aim 37 pin Deutsch Harness is the standard harness supplied with our MX Series Dash Loggers.
Suitable for MXS, MXP, MXG & MXm | Standard harness |
37 pin harness |
37 Pin Harness for the MX Series
The Aim 37 pins harness is the standard harness that comes with the MX Series Dash Loggers - MXS, MXP, MXG & MXm.
The Aim 37 pins Deutsch harness functions are listed below:
Digital wheel speed channel 1
CAN expansion
Power+
Ground-
CAN ECU connection
K-Line connection
Please Note: If you wish to add extra race data, then you will need the 22 pin Deutsch harness. This will add four more analogue channels (sensors). Available in the Accessories Tab.
Also available is our 37 pins Deutsch harness with a thermocouple connector. These are available with 1 or 2 thermocouple connectors and will enable you to connect thermocouple sensors.
These are some of the items that can be added to your car to improve performance and data.
- 37 pin Deutsch Female Flying Connector
- 5 pins Binder 712 Female Connector - See table in Downloads Tab
- 7 non-ended cables - See table in Downloads Tab
- 37 pin Deutsch Harness
The Aim 37 pin Deutsch Harness is the standard harness supplied with our MX Series Dash Loggers.Key Features :
37 pin harness |
The Aim 37 pins harness is the standard harness that comes with the MX Series Dash Loggers - MXS, MXP, MXG & MXm. This harness can be used to replace a damaged harness or for a second vehicle installation when sharing a dash logger.The Aim 37 pins Deutsch harness functions are listed below: Analogue sensor channels (sensors) 1, 2, 3, 4 Digital wheel speed channel 1 Optical lap timing sensor output CAN expansion Power+ Ground- CAN ECU connection K-Line connection Please Note: If you wish to add extra race data, then you will need the 22 pin Deutsch harness. This will add four more analogue channels (sensors). Available in the Accessories Tab. Also available is our 37 pins Deutsch harness with a thermocouple connector. These are available with 1 or 2 thermocouple connectors and will enable you to connect thermocouple sensors.
These are some of the items that can be added to your car to improve performance and data. ![]() |
