AiM Taipan Analog Channels & Second Injection Harness
SKU: C-H-AN-IN
- £45.00
- £45.00
The AiM Taipan Analog channels and second injection harness is an optional cable for the Taipan ECU.
Analog channels & second injection | JST connector |
5 flying wires |
AiM Taipan Accessories
The harness has a JST connector that connects to the Taipan ECU. Two flying cables for the second injection and three flying wires for analog channels.
UC Bridge - Optional Extra
User License:
A Taipan ECU comes with some basic maps that already give you better performance than the stock maps. Highly professional tuners all over the world offer specific maps that better fit your requirements, managing, for example, different exhaust, two injectors etc.
The UC Bridge is required for two functions:
Tuner License:
*Please Note: For information regarding the UC-Bridge Tuner, Please contact one of our Aim technical team for further information.
Taipan ECU Connections - Optional Extra
The Taipan ECU has 4 connectors:
The Aim Handlebar Switch is the best way for changing the behaviour of your bike; it features 2 pushbuttons, 10 LEDs and manages the following settings:
- JST Connector 08T-JWPF-VSLE-D
- Two flying wires:
- Red Wire - 12V Second INJ
- Black Wire - Second INJ CMD
- Three flying wires:
- Black Wire - GND
- White Wire - Spare Analog 1
- Blue Wire - Spare Analog 2
- Fill length - 2500mm
- Analog Channels & Second Injection Harness 2500mm - Full Length
The AiM Taipan Analog channels and second injection harness is an optional cable for the Taipan ECU.Key Features :
5 flying wires |
The AiM Taipan Analog channels and second injection harness is an optional cable for the Taipan ECU. The harness has a JST connector that connects to the Taipan ECU. Two flying cables for the second injection and three flying wires for analog channels. Below shows a functional diagram of products that can be added to the Taipan ECU:
User License: A Taipan ECU comes with some basic maps that already give you better performance than the stock maps. Highly professional tuners all over the world offer specific maps that better fit your requirements, managing, for example, different exhaust, two injectors etc.
Tuner License:
- Two flying wires:
- Black Wire - GND
Video
