Hopp til produktinformasjon
1 av 3
AiM Four-Way Data Hub CAN Connection Multiplier Kart
SKU: CAN-M-40
£65.00
£65.00
+ MVA (kun Storbritannia)
Drevet av Shopify Planet
The AiM four-way Data Hub provides a CAN channel and works as an interface between our AiM loggers and sensors.
Five pins 712 male Binder Four-way hub
CAN connection Build a network
The compact Data Hub provides four additional CAN channels and works as an interface between the AiM logger and its peripheral devices and accessories. Such as the LCU Lambda Controller, Memory key and SmartyCams.
The four-way Data Hub takes all the information you need to your logger with only one cable, minimizing wires overall.
You can use the four-way Data Hub with our Mychron's and loggers powered by the vehicles 12V onboard battery supply.
Two-way data hub with external power leads
Two-way data hub
  • Dimensions: 123 x 30 x 23.5mm
  • CAN cable length: 40/150cm
  • Weight: 97g
  • x 1 Four-way Data Hub
Two-way data hub
  • Weight: 97g
