Motorcycle Potentiometer Replacement Rose End Fitting
SKU: CASUS-P...
£8.50£10.20INC VAT - UK only
- £8.50
Replacement rose end joint fitting for the suspension potentiometer.
Key Features:
Replacement rose end fitting | Spare or replacement parts |
Aim Potentiometer Replacement Rose End Fitting
The motorcycle potentiometer rose joint fitting is a replacement part to fit the suspension potentiometer used to measure displacement between two points using a sensor.
Use as a replacement or spare part.
One Potentiometer Rose End Fitting Replacement Supplied.
- Replacement Potentiometer Rose End Fitting
- 1 x Rose End Fitting Potentiometer Replacement Fitting
Replacement rose end joint fitting for the suspension potentiometer.Key Features:
The motorcycle potentiometer rose joint fitting is a replacement part to fit the suspension potentiometer used to measure displacement between two points using a sensor. Use as a replacement or spare part.One Potentiometer Rose End Fitting Replacement Supplied.
