Aim MultiChron Hand Held Kart Digital Stopwatch
SKU: MULTI-K
- £105.00
- £105.00
Innovative. Programming. Accurate.
The Aim MultiChron Hand-Held Stopwatch is a unique multi-display stopwatch that enables the user to time up to 4 competitors simultaneously. Up to 99 lap times, plus up to 9 split times per lap, per competitor can be taken and stored in the memory. Each competitors' fastest, slowest and average times are shown. Moreover, you can quickly see the best laps and scroll all competitors' lap times to review the race.
The MultiChron features two different starting modes for a variety of racing situations.
"One Start" mode allows you to activate the start for all competitors pressing only one button: for races where all competitors start simultaneously.
"Multi Start" mode allows you to activate the start for each competitor independently: for races where competitors start at different times.
Multi-key Programming
Innovative programming allows you to get accurate times even when your racers are close together at the lap marker: selecting 'Multi Key', you can attribute times to each racer pressing 1,2,3 or 4 buttons. Selecting 'One Key', you get all four times pressing the same key and then attribute times to each racer.
Lightweight (100g batteries included) and all housed in a rugged case with a clear, bright display, MultiChron is the ideal tool for any competition.
Aim MultiChron Racing Stopwatch
- Dimensions: 25.5 x 29mm
- Weight: 100g Batteries Included
- 1/100 second precision
- Up to 99 lap times with up to 9 splits per lap
- Data recall while saving
- Automatic turn-off after 30 minutes of inactivity
- Two 3v batteries allow you to keep your data safe
- 1 x MultiChron Racing Stopwatch
