Hopp til produktinformasjon
1 av 3
AiM MyChron5 S 2T Patch Lead Double TR 719 Plug
SKU: P-712-TR-TR
£50.00
£50.00
The AiM MyChron 5 S 2T patch lead with double TR 719 connectors.
Double TR 710 plugs Suitable for fitting 2 x water temp sensors
Compatible with MyChron 4 & 5
The AiM MyChron5 S 2T patch lead with double TR 719 connector plugs will enable you to attach two water temperature sensors.
Cable length 1.5m
  • MyChron5 S 2T patch lead with double TR 719 plugs
  • Add two water temperature sensors with this patch lead
  • MyChron5 S 2T Patch Lead Double TR 719 Connector
The AiM MyChron5 S 2T patch lead with double TR 719 connector plugs will enable you to attach two water temperature sensors. Cable length 1.5m
