Hopp til produktinformasjon
1 av 3
AiM Solo 2 GPS Motorcycle Track Day Racing Lap Timer
SKU: SOLO2-K1
£350.00
£350.00
Integrated GPS
Ten configurable RGB LEDs
Wi-fi connectability
Graphical Display
4GB Internal Memory
Open or Closed track creation
Database with over 4000 Tracks worldwide
Multiple Race modes: Speed, Times & Performance
Automatic Track Recognition
Suitable for any motorsport vehicle
The most precise and easy way to get lap times
AiM Solo 2 receives data from two satellite constellations:  GPS and Glonass giving significant improvement in data speed and positioning precision as start-up times are reduced to seconds and lap times are accurate to a tolerance of two-hundredths of a second.
Solo 2 gives instant speed, timing splits live data, and predictive lap times.
The Solo 2 high contrast display helps drivers to easily identify the data displayed on the screen. The Solo 2 also features a selection of 7 different backlight colours, which you can select to suit your own personal requirements.
Even the predictive lap time is much more reliable and the configurable RGB LEDs will give you a clear and fast indication of the comparison with your best lap.
Data Recall On Screen
Solo 2 can be used for circuit racing and point to point or regularity events and performance tests such as 0-60mph. As with the circuit racing mode all data is recorded and can be reviewed immediately after each race or test session.
Solo 2 New Track Creation And Database
Solo 2 allows you to create a new temporary or permanent track layout. Whether it's a point to point run for rallying or a closed-loop track and if there is no track already, Solo 2 will create one for you.
The AIM Solo GPS Motorcycle Lap Timer is a cutting-edge technology device designed to meet the needs of motorcycle enthusiasts and racers. This lap timer is a powerful tool that provides accurate timing information for competitive racing or track day events. With its sophisticated GPS technology, the AIM Solo GPS Lap Timer offers precise lap times, speed, and position data, allowing riders to analyze and improve their performance on the track.
One of the key features of the AIM Solo GPS Motorcycle Lap Timer is its easy-to-use interface and user-friendly design. The lap timer is equipped with a high-resolution display that provides clear and detailed information at a glance. The device can be easily mounted on the motorcycle dashboard or handlebars, ensuring maximum visibility and ease of use while riding. With its intuitive menu system and customizable settings, riders can quickly navigate through the various functions of the lap timer and tailor it to their specific needs.
In addition to its timing capabilities, the AIM Solo GPS Motorcycle Lap Timer offers advanced data logging and analysis features. Riders can review detailed performance data from their track sessions, including lap times, speed, acceleration, and GPS position. This data can be exported to a computer for further analysis using AIM's Race Studio software, allowing riders to track their progress, identify areas for improvement, and optimize their racing strategy. With its comprehensive data tracking and analysis capabilities, the AIM Solo GPS Lap Timer is a valuable tool for serious motorcycle racers looking to take their performance to the next level.
With over 4000 tracks pre-loaded from around the world, as soon as it's switched on the Solo 2 identifies its position. Once you start to drive, it automatically recognises the start line coordinates of the track and starts sampling lap times every time you go past.
Wi-Fi Communication With The PC
The Solo 2 has integrated Wi-Fi, to enable you to review your data in more depth and transfer your data securely and quickly onto a laptop or computer up to 50m away without the need for connectors and cables. This data can then be imported into the Race Studio 3 software.
With Race Studio 3 you can create, modify, delete, import and export configurations with all channels, ECU drivers, Math channels, Display Pages, Digital outputs, Alarms, Shift Lights and all the expansions you need.
 Race Studio 3 can also analyse all data recorded by Solo 2 and download to your PC: graphs, histograms and tables to aid and study race techniques, which will ultimately provide objective support to avoid mistakes and improve overall performance.
AiM Solo 2 GPS Motocross Lap Timer
  • Display: Graphical
  • Display Pages: Up to 5 freely configurable
  • Wi-Fi connection: Yes
  • GPS: 10 Hz
  • External power: 12 V
  • Connectors : 1 socket (binder) 712, 5 pins
  • Memory: 4 GB
  • Pushbuttons: Metallic
  • Waterproof: IP67
solo2 pinout
  • Solo 2 power cable with car lighter socket
  • Power cable with AC adapter
Integrated GPS
Graphical Display
4GB Internal Memory
The AIM Solo GPS Motorcycle Lap Timer is a cutting-edge technology device designed to meet the needs of motorcycle enthusiasts and racers. This lap timer is a powerful tool that provides accurate timing information for competitive racing or track day events. With its sophisticated GPS technology, the AIM Solo GPS Lap Timer offers precise lap times, speed, and position data, allowing riders to analyze and improve their performance on the track. One of the key features of the AIM Solo GPS Motorcycle Lap Timer is its easy-to-use interface and user-friendly design. The lap timer is equipped with a high-resolution display that provides clear and detailed information at a glance. The device can be easily mounted on the motorcycle dashboard or handlebars, ensuring maximum visibility and ease of use while riding. With its intuitive menu system and customizable settings, riders can quickly navigate through the various functions of the lap timer and tailor it to their specific needs. In addition to its timing capabilities, the AIM Solo GPS Motorcycle Lap Timer offers advanced data logging and analysis features. Riders can review detailed performance data from their track sessions, including lap times, speed, acceleration, and GPS position. This data can be exported to a computer for further analysis using AIM's Race Studio software, allowing riders to track their progress, identify areas for improvement, and optimize their racing strategy. With its comprehensive data tracking and analysis capabilities, the AIM Solo GPS Lap Timer is a valuable tool for serious motorcycle racers looking to take their performance to the next level.
Technical Specifications
  • GPS: 10 Hz
  • Memory: 4 GB
  • Waterproof: IP67
solo2 pinout
