Hopp til produktinformasjon
1 av 2
AiM Solo & Solo 2 & Solo 2 DL Suction Cup Mount
SKU: SOLO-WM
£67.00
£67.00
The AiM suction cup mount is suitable to fit the windscreen or a flat surface. Used to secure for Solo GPS lap timer to your car.
Secure mounting for GPS lap timer Ball & socket for positioning
Suitable for Solo, Solo 2 & Solo 2 DL
Suction Cup Mount for GPS Lap Timer
The AiM suction cup mount to suit the Solo, Solo 2 and Solo 2 DL has been designed to securely mount the Solo GPS lap timer to any flat surface such as your windscreen.
It has a 90mm locking and quick release suction cup, also a dual swivel joint making viewing angle adjustment quick and easy.
  • 90mm arm
  • Suction cup
  • Clamp base with ball
  • Locknut
  • Screws and washers
  • 1 suction cup Mount Bracket for Solo, Solo 2, Solo 2 DL
  • 90mm arm
  • Suction cup
  • Locknut
