Aim Two-Way Data Hub CAN Connection Multiplier
SKU: CAN-M2-40
£60.00£72.00INC VAT - UK only
- £60.00
Aim Two-way Data Hub CAN Connection Multiplier
The Aim two-way data hub provides CAN channels and works as an interface between our Aim loggers and sensors.
Key Features:
Five pins 712 male Binder | Two-way hub |
Cable length - 40cm | Build a network |
Two-Way Data Hub
The compact two-way data hub provides CAN channels and works as an interface between our loggers and equipment such as LCU lambda controller, GPS module, TC hub, SmartyCams and many more.
The two-way data hub takes all the information you need to your logger with only one cable, minimising wires overall.
Our data hubs are also available in the following versions:
- Four-way data hub
- Two-way data hub with external power connection - Usually used on karts
Connecting the Two-Way Data Hub
These are some devices that can add extra data to your vehicle to improve performance and data.
You can connect more data hubs to build a network, as shown in the image.
- Dimensions: 70 x 30 x 23.5mm
- CAN cable length: 40cm
- Weight: 86g
- x1 Two-way Data Hub
The Aim two-way data hub provides CAN channels and works as an interface between our Aim loggers and sensors.Key Features:
Two-Way Data Hub
The compact two-way data hub provides CAN channels and works as an interface between our loggers and equipment such as LCU lambda controller, GPS module, TC hub, SmartyCams and many more.Using many devices can result in excessive wiring. Thanks to the data hub, it can eliminate all unnecessary wiring. The two-way data hub takes all the information you need to your logger with only one cable, minimising wires overall. Our data hubs are also available in the following versions:
- Four-way data hub
These are some devices that can add extra data to your vehicle to improve performance and data. You can connect more data hubs to build a network, as shown in the image.
- Weight: 86g
