Hyundai i20 R5 2016 Aim SmartyCam 3 Corsa Kit
SKU: Hyunda-SM3
- £1,150.00
- £1,150.00
Compact, Advanced, Precise
Enhance your Hyundai i20 R5's performance with the AiM SmartyCam 3 Corsa Kit, specifically designed for models from 2016.
Supported Models and years
Hyundai i20 R5from 2016
Standalone Feature
The SmartyCam 3 Corsa provides you with a CAN expansion that connects with many Aim devices such as the Solo 2 DL Laptimer, various Aim Dash Display Loggers, and PDM Dash systems. This is a standard practice within our products, however we have also equipped the SmartyCam 3 Corsa with unterminated CAN connections which allow you to connect the camera to any system as a standalone feature. No matter your vehicle and equipment, with the unterminated connectors you can run the Corsa through your CAN/ECU connections.
Quality
Anatomy
Finished with a sleek new look, the SmartyCam 3 Corsa is assured to add efficiency, informational data, productivity, and style to your racing. AiM SmartyCam 3 Corsa allows you to connect ECU direct to your camera with b connectors. Here at AiM, we provide only the best innovations and are constantly and consistently working to better your racing experience.
Higher Storage Capacity
SD cards sold separately.
- CMOS sensor: Global Shutter
- Field of view: 67°, 84°
- External power: 9-15 Volt
- Connectors: 3 Binder 712 female 1 USB-C
- Auto Power ON: Yes
- Auto Power OFF: Yes
- Dimensions: 102.2 x 63 x 46.5 mm
- Weight: 280g, battery included
- Waterproof: IP65-rated to withstand the rigours of motorsport, this kit offers durability and reliability for Hyundai i20 R5 drivers
Channels received by AiM devices configured with Hyundai i20 R5 protocol are:
Channel Name | Function |
RPM | Engine speed |
Gear | Selected gear |
Speed | Vehicle speed |
PBrakeFront | Front brake pressure |
PBrakeR | Rear brake pressure |
ASteer | Steering wheel angle |
PedalPos | Pedal position sensor |
RotMAPPos | Rotary map position |
- SmartyCam 3 Corsa
- USB-C Cable
2m CAN Cable
- 712 5 Pin Male
Standalone Feature
Quality
Anatomy
Technical Specifications
Hyundai i20 R5 Protocol
What's In The Box
- SmartyCam 3 Corsa
- USB-C Cable
2m CAN Cable
- 712 5 Pin Male
