Hopp til produktinformasjon
1 av 2
Link Mitsubishi EVOLink (I-III) - EVO3X PlugIn ECU
SKU: EVO3X
£995.00
£995.00
This ECU is designed for the EVO 1-3 4G63 engine.
Includes onboard 4 bar MAP sensor
Air temp sensor highly recommended.
Suitable Applications:
Mitsubishi EVO 1 1992-1994*
Mitsubishi EVO 2 1994-1995*
Mitsubishi EVO 3 1995-1996*
*Chassis number for these cars should be CD9A or CE9A.
Mitsubishi GSR 1.8L 4G62
Sequential fuel delivery
OEM idle hardware supported
CAN port
USB tuning cable included
Staged injection
Knock with "windowing"
I/O Expansion Options:
Expansion connector 1
Gnd Sensor Ground Only
+5V Low Current +5V Supply
DI 9 Digital Input
DI 8 Digital Input
Volt 5 Analog 0-5V input
Volt 6 Analog 0-5V input
Temp 3 Temperature sensor input
Temp 4 Temperature sensor input
Expansion connector 2
Ign 5 Ignition 5 Auxiliary Output
Volt 8 Analog 0-5V input
Volt 9 Analog 0-5V input
Volt 10 Analog 0-5V input
Volt 11 Analog 0-5V input
  • G4X PlugIn ECU
  • Stickers
CAN port
Staged injection
DI 9 Digital Input
DI 8 Digital Input
Temp 4 Temperature sensor input Expansion connector 2  Ign 5 Ignition 5 Auxiliary Output
  • G4X PlugIn ECU
  • Stickers
