Hopp til produktinformasjon
1 av 2
Link Nissan 300Link - #N300X PlugIn ECU
SKU: N300X
£1,355.00
£1,355.00
The N300X ECU is Designed to suit the VG30DET engine.
Includes an onboard 4 bar or 7 bar MAP sensor.
It is highly recommended to fit an IAT sensor with this model.
Suitable Applications:
Z32 300ZX VG30DE
Z32 300ZX VG30DETT
PlugIn Key Features:
Sequential fuel delivery
OEM idle hardware supported
CAN port
USB tuning cable included
Staged injection
Knock with "windowing"
I/O Expansion Options:
Expansion connector 1
DI 5 Digital Input
DI 6 Digital Input
Volt 8 Analog Volt Input
Volt 7 Analog Volt Input
Temp 3 Analog Temp Input
Temp 4 Analog Temp Input
Expansion connector 2
Gnd Sensor Ground Only
DI 7 Digital Input
DI 8 Digital Input
An Volt 9 Analog 0-5V input
An Volt 10 Analog 0-5V input
  • G4X PlugIn ECU
  • Stickers
Z32 300ZX VG30DE
Z32 300ZX VG30DETT
CAN port
Staged injection
Expansion connector 1 +5V Out Low Current +5V Supply
DI 5 Digital Input
DI 6 Digital Input
Temp 4 Analog Temp Input Expansion connector 2  Gnd Sensor Ground Only
DI 7 Digital Input
DI 8 Digital Input
  • G4X PlugIn ECU
  • Stickers
