Link Nissan GTR - NGTR-X PlugIn ECU
SKU: NGTRX
- £1,475.00
- £1,475.00
The NGTRX is Designed to suit the blue plug Nissan RB engine.
This model includes an onboard 4 bar or 7 bar MAP sensor.
Suitable Applications:
RB26DETT engines found in R32, R33, R34 Skyline GTRs and Autech 260RS Stageas
RB20DE engines found in R32 & R33 Skylines, A31 Cefiros
RB20DET engines found in R32 Skylines (incl 4wd), A31 Cefiros and C33 Laurels. – Injector 4&6 need swapping
RB25DE engines found in R32 & R33 Skylines, C33 & C34 Laurels and A31 Cefiros.
RB25DET engines found in R33 Skylines (incl 4wd) and C34 Laurels
RB30DE/DET/DETT engines made using Non-Neo heads and blue plug looms
PlugIn Key Features (where applicable):
Sequential fuel delivery
OEM idle hardware supported
CAN port
USB tuning cable included
Staged injection
Knock with "windowing"
I/O Expansion Options:
Expansion connector 1
Gnd Sensor Ground Only
DI5 Digital Input
DI6 Digital Input
An Volt 8 Analog 0-5V input
An Volt 2 Analog 0-5V input
Expansion connector 2
DI 9 Digital Input
DI 10 Digital Input
An Volt 10 Analog 0-5V input
Aux 11 Auxiliary Output 11
Link Nissan GRTLink - NGTR-X ECU
- G4X PlugIn ECU
- Stickers
RB26DETT engines found in R32, R33, R34 Skyline GTRs and Autech 260RS StageasRB20DE engines found in R32 & R33 Skylines, A31 Cefiros
CAN port
Staged injection
The following expansion connector inputs/outputs are provided:Expansion connector 1
DI5 Digital Input
DI6 Digital Input
An Temp 4 Temperature sensor input Expansion connector 2
DI 9 Digital Input
DI 10 Digital Input
- G4X PlugIn ECU
- Stickers
