Link Toyota MR2Link V1 - TST185X PlugIn ECU
SKU: TST185X
- £1,145.00
- £1,145.00
Designed for the 3SGTE engine in the models specified below.
A Link Air Temp Sensor is highly recommended with this ECU
Suitable Applications:
Toyota MR2 (SW20) from 1989 to 1992
Toyota Celica ST185 (except the GT-Four RC/Carlos Sainz Special Edition which is compatible with the Link TST205X Plugin)
Sequential fuel delivery
OEM idle hardware supported
CAN port
USB tuning cable included
Staged injection
Knock with "windowing"
I/O Expansion Options:
Expansion connector:
Gnd Sensor Ground Only
DI 5 Digital Input for switching functions.
DI 6 Digital Input for switching functions.
DI 4 Digital Input for switching functions.
An Volt 4 Analog 0-5V input
An Volt 5 Analog 0-5V input
An Volt 6 Analog 0-5V input
An ignition expansion is provided allowing you to convert to a Direct Spark ignition system. Alternatively, these outputs can be used to drive auxiliary devices. The following pinout describes the available connections.
Ignition Expansion:
1 Ignition 1
2 Ignition 2
3 Ignition 4
4 Ignition 3
- G4X PlugIn ECU
- Stickers
Toyota MR2 (SW20) from 1989 to 1992Toyota Celica ST185 (except the GT-Four RC/Carlos Sainz Special Edition which is compatible with the Link TST205X Plugin)
CAN port
Staged injection
The following expansion connector inputs/outputs are provided:Expansion connector:
An Volt 6 Analog 0-5V input An ignition expansion is provided allowing you to convert to a Direct Spark ignition system. Alternatively, these outputs can be used to drive auxiliary devices. The following pinout describes the available connections.
Ignition Expansion:
1 Ignition 1
2 Ignition 2
3 Ignition 4
4 Ignition 3
- G4X PlugIn ECU
- Stickers
