M-Sport Ford Fiesta Rally 2 Aim SmartyCam 3 Dual Kit - MK2 from 2022
SKU: FORD-SM3-D
- £1,660.00
- £1,660.00
Dual Full HD camera system, Video output, CAN connection, USB-C connection, Ethernet port are only few of the features of SmartyCam 3 Dual: the most powerful of our range.
The new SmartyCam 3 Dual saves all your information to a supported SD card for up to 2TB of data, this includes speed, RPM, lap number, gear shifts and many more features. With a built-in data logger running on an external power of 9-15 volts, the new SmartyCam 3 Dual automatically powers on and off in-sync with your engine – and will start/stop recording for you. Analyse your data from a vast range of sources such as GPS track map, vehicle position and speed, lap & split times. Video format is at H.264 1920x1080 pixels, 60 FPS, and the display resolution of 2.4” 240x320 pixels gives your footage crisp condition.
Our quality doesn’t falter, even under the pressure of extreme motorsport conditions such as poor weather, strong vibrations, continuous rain, and high/low temperatures as extreme as -10°C to + 50°C. Our camera is also waterproof (IP65) for extra protection.
Supported Models and years
M-Sport Ford Fiesta Rally 2 Mk2from 2022
If specifically set by M-Sport, these models feature a CAN data bus accessible to AiM devices through a Deutsch DTM06-2S connector located by/behind the co-driver’s foot plate, labelled CAN3.
Video Output/Streaming
Picture in Picture
Standalone Feature
The SmartyCam 3 Dual provides you with a CAN expansion that connects with many Aim devices such as the Solo 2 DL Laptimer, various Aim Dash Display Loggers, and PDM Dash systems. This is a standard practice within our products, however, we have also equipped the SmartyCam 3 Dual with unterminated CAN connections which allow you to connect the camera to any system as a standalone feature. No matter your vehicle and equipment, with the unterminated connectors you can run the Dual through the CAN/ECU connections of your choosing.
Quality
Anatomy
Higher Storage Capacity
SD cards sold separately.
- CMOS sensor: Global Shutter
- Video Out: 3G-SDI
- External power: 9-15 Volt
- Auto Power ON: Yes
- Auto Power OFF: Yes
- Body: Anodised Aluminium
- Waterproof: IP65-rated to withstand the rigours of motorsport, this kit offers durability and reliability for M-Sport Ford Fiesta Rally 2 drivers
Channels received by AiM devices configured with Ford M-Sport 22 protocol are:
Channel Name | Function |
RPM | RPM |
Vehicle Speed | Vehicle speed |
Gear FIA | Engaged gear |
Steering Wheel | Steering wheel angle position |
Pedal Pos | Throttle pedal position |
Brake Press Fr | Front brake pressure |
Brake Press Rr | Rear brake pressure |
Turbo Speed | Turbo speed |
Engine Cool Temp | Engine coolant temperature |
Engine Oil Temp | Engine oil temperature |
Air Charge Temp | Air charge temperature |
Exhaust Temp | Exhaust gas temperature |
Oil Pressure | Oil pressure |
MAP | Manifold air pressure |
ALS Cal | Anti lag system calibration |
- SmartyCam 3 Dual
- External Power Cable
- USB-C Cable
- 2 Bullet Cameras
- 2 Co Ax Cables
- Complete CAN / RS232 & Expantion With Ethernet Connection & External Mic Harness
Standalone Feature
Quality
Anatomy
Technical Specifications
- Video Out: 3G-SDI
Ford M-Sport 22 Protocol
RPM | RPM |
What's In The Box
- SmartyCam 3 Dual
- USB-C Cable
- 2 Bullet Cameras
- 2 Co Ax Cables
