Hopp til produktinformasjon
1 av 6
Skoda Fabia R5 Aim SmartyCam 3 Dual Kit - R5 2015 to 2018 - R5 EVO2 from 2019
SKU: SKODA-SM3-D
£1,660.00
£1,660.00
Enhance your Skoda Fabia R5's performance with the AiM SmartyCam 3 Dual Kit, specifically designed for models from 2015 to 2018 and the EVO2 from 2019. Engineered for any racer who wants to get the most out of any performance video on the track, the SmartyCam 3 Dual is the flagship version of SmartyCam 3 range.
Dual Full HD camera system, Video output, CAN connection, USB-C connection, Ethernet port are only few of the features of SmartyCam 3 Dual: the most powerful of our range.
The new SmartyCam 3 Dual saves all your information to a supported SD card for up to 2TB of data, this includes speed, RPM, lap number, gear shifts and many more features. With a built-in data logger running on an external power of 9-15 volts, the new SmartyCam 3 Dual automatically powers on and off in-sync with your engine – and will start/stop recording for you. Analyse your data from a vast range of sources such as GPS track map, vehicle position and speed, lap & split times. Video format is at H.264 1920x1080 pixels, 60 FPS, and the display resolution of 2.4” 240x320 pixels gives your footage crisp condition.
Our quality doesn’t falter, even under the pressure of extreme motorsport conditions such as poor weather, strong vibrations, continuous rain, and high/low temperatures as extreme as -10°C to + 50°C. Our camera is also waterproof (IP65) for extra protection.
Skoda Fabia R5
Supported Models and years
  • Skoda Fabia R5
    2015 - 2018
  • Skoda Fabia R5 EVO2
    from 2019
These models feature a loom extension supplied by the car manufacturer which has a DTM 4 pin connector on one end carrying CAN and power supply contacts.
smartycam icon
Video Output/Streaming
SmartyCam 3 Dual features a video output with SD interface. It allows you to send the video/audio directly to wherever you choose, for example your pit crew, at 30 or 60fps.
Two Video Inputs
Picture in Picture
smartycam icon
With the built-in data logger, you can view all the channels displayed on the video footage and review them with our new Race Studio 3 analysis software. Such channels include RPM, throttle, engaged gears, acceleration, temperatures, and pressures including a tri-axis accelerometer measuring 16G.
smartycam icon
Standalone Feature
The SmartyCam 3 Dual provides you with a CAN expansion that connects with many Aim devices such as the Solo 2 DL Laptimer, various Aim Dash Display Loggers, and PDM Dash systems. This is a standard practice within our products, however, we have also equipped the SmartyCam 3 Dual with unterminated CAN connections which allow you to connect the camera to any system as a standalone feature. No matter your vehicle and equipment, with the unterminated connectors you can run the Dual through the CAN/ECU connections of your choosing.
smartycam icon
Quality
smartycam icon
Anatomy
smartycam icon
Higher Storage Capacity
Generic HD cameras focus too much on pixel numbers resulting in large file sizes. The SmartyCam 3 footage has the same quality as other FHD cameras with smaller files due to H.264 compression system parameters being optimised to a perfect balance between video quality and file size. Choose between three file quality levels: One hour recording = 4GB (High Quality), 2GB (Normal Quality) or 1.5GB (Lower quality).
SD cards sold separately.
smartycam icon
The SmartyCam 3 Dual Kit seamlessly integrates with the Skoda Fabia R5's ECU, providing real time data overlays for enhanced performance analysis. The SmartyCam 3 Dual can be connected through the CAN network to our AiM Loggers, MX Series, MXL2, MyChron, Solo2 DL, EVO5 and ECU Bridge.
smartycam icon
Upgrade your Skoda Fabia R5 with the AiM SmartyCam 3 Dual Kit today and experience unparalleled data insights for yourself!
  • CMOS sensor: Global Shutter
  • Video Out: 3G-SDI
  • External power: 9-15 Volt
  • Auto Power ON: Yes
  • Auto Power OFF: Yes
  • Body: Anodised Aluminium
  • Waterproof: IP65-rated to withstand the rigours of motorsport, this kit offers durability and reliability for Skoda Fabia R5 drivers
smarty cam 3 sport connectors
smartycam3 dual pinout
Channels received by AiM devices configured with Skoda Fabia R5 protocol are:
Channel Name Function
RPM Engine speed
Gear Selected gear
Car Speed Vehicle speed
AccelPedal Pedal accelerator ratio
FrontBrkPress Front brake pressure
pHandBrake Handbrake pressure
SteeringPos Steering position Angle
TripDist2 Trip distance 2
GDUOutLed GDU output led
StRoadMode Status road mode (=1) - Special stage (=0)
  • SmartyCam 3 Dual
  • External Power Cable
  • USB-C Cable
  • 2 Bullet Cameras
  • 2 Co Ax Cables
  • Complete CAN / RS232 & Expantion With Ethernet Connection & External Mic Harness
Skoda Fabia R5
  • Skoda Fabia R5
    2015 - 2018
    from 2019
smartycam icon
Two Video Inputs
With two video inputs you can film from two locations on your vehicle which can be displayed on 'Picture in Picture using Race Studio 3, essentially allowing you to overlay and analyse your driving from any two angles you like. Picture in Picture Overlay your videos with our all-new 'Picture in Picture' effect. Pick your angles and drive; you can configure auto start/stop to do the rest, and stream your video at 30 or 60 FPS straight to your pit crew, or even Facebook, Youtube - you name it - with a built-in ethernet connection.
smartycam icon
smartycam icon
Standalone Feature
smartycam icon
Quality
smartycam icon
Anatomy
smartycam icon
smartycam icon
smartycam icon
Technical Specifications
  • Video Out: 3G-SDI
Skoda Fabia R5 Protocol
RPM Engine speed
Gear Selected gear
What's In The Box
  • SmartyCam 3 Dual
  • USB-C Cable
  • 2 Bullet Cameras
  • 2 Co Ax Cables
