Hopp til produktinformasjon
1 av 5
Yamaha YZF-R1/R1M & YZR-R6 AiM Solo 2 DL & SmartyCam 3 GP Motorcycle Plug & Play Lap Timer Track Day Kit
SKU: SOLO2-K-YAM-1-SM-CAM-GP-2-SM-GPC-XB1SGPH22B67L200-V0256934CS-X47SOLO2DL02
£2,210.00
£2,210.00
Yamaha YZF-R1/R1M & YZF-R6 AiM Solo 2 DL & SmartyCam 3 GP  Motorcycle Plug & Play Lap Timer Track Day Kit
The Yamaha plug & play kit combined with the Solo 2 DL and SmartyCam 3 GP  gives you the ultimate track day experience.
Database with more than 4,000 tracks worldwide Yamaha ECU connection cable
This ultimate track day kit has been specifically designed for Yamaha bikes. The kit includes a plug & play interface cable and bracket for your bike. A Solo 2 DL to give you the most precise lap times and the incredibly robust SmartyCam 3 GP to record your races and provide all the technical layovers to help improve your performance. Also added is our 3 GP bullet camera clamp mount to enable you to position the bullet camera on your bike. Connecting the Solo 2 DL to your Yamaha ECU will give you all the engine performance information you need to help improve your driving performance.
SmartyCam 3 GP Features:
Yamaha YZF-R1 - From 2015 Yamaha YZF-R1M - From 2015
Yamaha YZF-R6 - From 2017
Powerful Combination
Yamaha YZF-R1
SmartyCam 3 GP
Automatic Start/Stop
Yamaha YZF-R1
  • Display: Graphical
  • Wi-Fi connection: Yes
  • GPS: 10 Hz
  • External power: 12 V
  • Memory: 4 GB
  • Pushbuttons: Metallic
  • Waterproof: IP67
  • SmartyCam 3 GP
  • CMOS sensor: Global Shutter
  • Video Out: 3G-SDI
  • External power: 9-15 Volt
  • Auto Power ON: Yes
  • Auto Power OFF: Yes
  • Body: Anodised Aluminium
  • Dimensions: Main Body -154.4x109.6 x 42mm, Bullet Camera - 24diam x 48.2mm
  • Waterproof: IP65
  • Solo 2 DL
  • Power cable with AC adapter
  • SmartyCam 3 GP - Bullet Cam
  • External CAN cable 2m
  • External power cable
  • Yamaha Plug & Play connection cable
  • Bracket
  • 1 rubber dowel
  • 1 Allen screw with flat head M6
  • 1 rubber washer
  • 2 Allen screws with flat head M4 x 10
This ultimate track day kit has been specifically designed for Yamaha bikes. The kit includes a plug & play interface cable and bracket for your bike. A Solo 2 DL to give you the most precise lap times and the incredibly robust SmartyCam 3 GP to record your races and provide all the technical layovers to help improve your performance. Also added is our 3 GP bullet camera clamp mount to enable you to position the bullet camera on your bike. Connecting the Solo 2 DL to your Yamaha ECU will give you all the engine performance information you need to help improve your driving performance. SmartyCam 3 GP Features:
The Yamaha ECU interface cable provides a plug & play solution for connecting the Solo 2 DL lap timmer to your bike. Please refer to the technical sheet on how to connect the ECU cable to your bike. The sampled data you record depends on the actual ECU but typically includes RPM, engine load, throttle position (TPS), oil, air, water temperature, oil pressure, battery voltage, speed, gear and lambda value (air/fuel). The list of ECUs is forever growing and being updated. With the added SmartyCam 3 GP camera you create an even more powerful system to help provide great videos that include all the technical information to help improve your performance. The SmartyCam 3 GP has four connections, one that is completely dedicated to the bullet cam, one for the ECU-MIC, one for a GPS Module connection and the final connector is for outputting the video footage for streaming. Please Note: For these models/years Aim recommends not to remove the stock dash. Doing so will disable some of the bike functions or safety controls.
The GPS technology provides better reliability from the predictive lap timing function so you can see in real-time how your current lap compares to your best lap. The LEDs are also configurable to give a visual indication of whether you are quicker or slower. You can also build the layout of the display to show the data you want to see. Solo 2 DL gives instant speed, timing splits live data and predictive lap times. The Solo 2 DL has a sharp, high contrast display which helps drivers easily identify the data displayed on the screen. The Solo 2 DL also features a selection of 7 different backlight colours which can be selected to suit your requirements.
Yamaha YZF-R1
SmartyCam 3 GP
The new SmartyCam 3 GP saves all your information to a supported micro-SD card for up to 2TB of data, this includes speed, RPM, lap number, gear shifts and many more features. With a built-in data logger running on an external power of 9-15 volts, the new SmartyCam 3 automatically powers on and off with your engine – and will start/stop recording for you. Analyse your data from a vast range of sources such as GPS track map, vehicle position and speed, and lap & split times. T format is at H.264 1920x1080 pixels, 60 FPS, and the display resolution of 2.4” 240x320 pixels gives your footage crisp condition. Our quality doesn’t falter, even under the pressure of extreme motorsport conditions such as poor weather, strong vibrations, continuous rain, and high/low temperatures as extreme as -10°C to + 50°C. Our camera is also waterproof (IP65) for extra protection. SmartyCam 3 GP features a video output with SD interface. It allows you to send the video/audio directly to wherever you choose, for example your pit crew, at 30 or 60fps. With the built-in data logger experience enhanced RPM, throttle, engaged gears, acceleration, temperatures, and pressures including a tri-axis accelerometer measuring 16G.
Yamaha YZF-R1
  • GPS: 10 Hz
  • Memory: 4 GB
  • Waterproof: IP67
  • SmartyCam 3 GP
  • Video Out: 3G-SDI
  • Waterproof: IP65
  • Solo 2 DL
  • Bracket
  • 1 rubber dowel
  • 1 rubber washer
