Aim ACC 3 Analogue CAN Converter
SKU: ACC-2
£250.00£300.00INC VAT - UK only
- £250.00
ENHANCE YOUR LOGGER PERFORMANCE ACC 3 is the new compact and powerful Analogue CAN Converter that manages up to four channels at 200Hz each. Now compatible with the Aim Solo 2 DL.
With Race Studio 3, you can also analyse all data recorded and download it to your PC: graphs, histograms and tables will help you study your performance, providing objective support to avoid mistakes and improve performances.
ACC 3 - Analogue CAN Converter
- Analogue channels: 4 fully configurable channels, 24 bit, A/D, 200Hz each: TC (with dedicated cable), TR, 0-5V, 0-12V
- Speed Inputs: 2 (AN3-AN4), max frequency 10kHz, internal pull-up for open drain/collector input
- External power: 9-15V operational 12-15V fully operational
- Connection: CAN
- Connectors: 2 Binder 712 fem connectors
- Material: PA6 30% glass
- Dimensions: 44.0 x 38.0 x 19.8mm
- Weight: 50g
- AC C3 Converter
- CAN cable
- 4 channels harness
With Race Studio 3, you can create, modify, delete, import and export configurations with all channels, ECU drivers, Math channels, Display Pages, Digital outputs, Alarms, Shift Lights and all the expansions you need. You will also be able to manage the map of all your racing tracks and compare two laps by watching the video recorded by SmartyCam HD cameras.Analysis
With Race Studio 3, you can also analyse all data recorded and download it to your PC: graphs, histograms and tables will help you study your performance, providing objective support to avoid mistakes and improve performances. ![]() |
- Connection: CAN
- Weight: 50g
- AC C3 Converter
- CAN cable
