Gå til produktinformasjon
1 av 4
Aim 10" TFT Dash Display with Race Icons for PDM08/PDM32
SKU: DISPLAY-10-XC1D10000NI
£545.00
£545.00
A high-visibility 10-inch TFT display designed exclusively for Aim PDM08/PDM32. The display offers customisable layouts, race icons and shift lights—ideal for serious racers needing advanced, integrated data visualisation and control
An Advanced Motorsport PDM Display
The Aim 10" TFT Dash Display with race icons is suitable as a replacement unit for those supplied with the Aim PDM Kits or an upgrade for PDM Kits that do not include a dash display.
Display Key Features
Race Icons
6 Status Information LEDs
10 Shift Light LEDs
Fully Configurable Display
Designed For PDM08/PDM32
Why Choose The Aim 10" TFT Dash Display with Race Icons for PDM08/PDM32
The Aim 10" TFT Dash Display with Race Icons is designed exclusively for integration with Aim PDM08 and PDM32 Power Distribution Modules (PDMs). This display serves as a comprehensive replacement for traditional dashboard gauges and warning lights, offering a modern, customisable interface tailored for motorsport applications.
Suitable for replacing all of the dashboard gauges and warning lights, the TFT Dash Display provides a 10" screen with a resolution of 1280 x 480 pixels, providing clear and sharp visuals. An ambient light sensor also automatically adjusts screen brightness depending on surrounding lighting conditions for optimal visibility of data.
This specific display is available with race icons to allow drivers to see critical information during intense motorsport environments. The display is also available with road icons to suit a variety of applications, both offering full user-configurable displays and a range of layouts.
LEDs & Shift Lights
Equipped with 6 status information LEDs and 10 multi-coloured RGB shift light LEDs, offering immediate visual alerts and notifications.
Compatibility & Integration
The 10" Dash Display is ONLY for use with Aim PDM Kits and can not be used as a standalone dash display. It connects via an LVDS Link 4-pin Rosenberger male connector, facilitating reliable and high-speed data transmission between the display and PDM.
Check out the “Downloads” tab for all the information required on connection and programming to the PDM08 and the PDM32.
Mirror Camera For PDM
Optional Mirror Camera
The display supports the addition of up to 2 cameras. The Mirror/Reversing Camera (sold separately) allows the display to function as a reversing mirror or provide front and rear views — ideal for cars with limited rear vision. The camera inputs can be activated through a button press or configurable events.
Please note: You will require a PDM32 for this function to work.
Add extra devices to your system to give additional data and improve your racing performance, such as GPS Module, Channel Expansion, TC Hub, SmartyCam HD, Lambda Controller, Remote I/O Pushbutton Module, Formula Steering Wheel, TPMS System and Keypads.
With Race Studio 3, you can create, modify, delete, import, and export configurations with all channels, ECU drivers, Math channels, Display Pages, Digital outputs, Alarms, Shift Lights, and all the expansions you need. You will also be able to manage the map of all your racing tracks and compare two laps by watching the video recorded by SmartyCam HD cameras.
With Race Studio 3, you can also analyse all data recorded by the PDM Display and download it to your PC: graphs, histograms, and tables will help you study your performance, providing objective support to avoid mistakes and improve performance.
  • Display: 10" TFT
  • Resolution: 1280 x 480 pixels
  • Contrast: 1,100:1
  • Brightness: 800cd/m
  • Ambient Light Sensor: Yes
  • Status information LEDs: 6
  • Shift Light LEDs: 10
  • Body: Anodised Aluminium
  • Pushbuttons: Metallic
  • Connectors: LVDS Link 4 Pins Rosenberger male connector
  • Dimensions: 278.0 x 135.0 x 26.2mm
  • Weight: 1000 g
  • Power consumption: 250 mA
  • 10" TFT Dash Display with Race Icons
Race Icons
10 Shift Light LEDs
LEDs & Shift Lights
  • Display: 10" TFT
  • Contrast: 1,100:1
  • Weight: 1000 g
What's In The Box
