AiM Strada 1.2 23 Pin Motorcycle Analogue Harness MXS, MXP, MXG
SKU: MX-S-L-AN
- £160.00
- £160.00
+ MVA (kun Storbritannia)
AiM 23 Pin Strada 1.2 Analog Loom for MXS, MXP, MXG
The AiM 23 pin AMP connection harness is an optional extra for the Strada MXS, MXP, MXG dash displays.
Fits MXS, MXG, MXG dashes | Replacement for original wiring |
23 pin AMP female connector | 4 pin binder 719 female |
4 cables | |
23 Pin Analog Loom
The AiM 23 pin AMP connector is an optional harness with pre-wired connections. Offering 4 analogue, speed and lap channels all being terminated with 719 female binder plugs.
These plugs can be extended to suit your requirements by purchasing the 719-719 patch leads which are available in the accessories tab.
The 23 pin AMP connection provides:
Analogue channels 1-4
Speed
Lap
RS232tx/rx
Digital output
CAM2+/-
Please Note: This harness is an optional tool to help you gain more data and add extra sensors to your kit should you require them.
- 23 pins AMP female connector
- X 4 Cables - 1 x 0.5
- 4 X 0.35 cables +
- 3 X 0.35 cables
- 4 pins Binder 719 female connector
- 23 Pin Strada 1.2 Analog Loom
The AiM 23 pin AMP connection harness is an optional extra for the Strada MXS, MXP, MXG dash displays.Key Features :
4 cables | |
23 Pin Analog Loom
The AiM 23 pin AMP connector is an optional harness with pre-wired connections. Offering 4 analogue, speed and lap channels all being terminated with 719 female binder plugs.These plugs can be extended to suit your requirements by purchasing the 719-719 patch leads which are available in the accessories tab.
Speed
Lap
RS232tx/rx
Digital output
CAM2+/-
- 4 X 0.35 cables +
- 3 X 0.35 cables
