Gå til produktinformasjon
1 av 3
Aim 712-719 Male to Female 4 Pin Patch Lead Kart
SKU: P-712-7...
£40.00
£48.00
INC VAT - UK only
£40.00
£40.00
£48.00
INC VAT - UK only
£40.00
The Aim 712-719 male to female 4 pin patch lead extends the original wiring harness, e.g. when fitting analogue sensors.
712-719 patch lead 4 pin male to female
Extends wiring harness Various lengths available
The Aim 712-719 male to female 4 pin patch lead extends the original wiring harness, e.g. when fitting analogue sensors. Available in different lengths to suit your application.
Use this patch lead to connect your EVO4/EVO4S logger or Channel Expansion device to various analogue sensors. You can also extend the cable length further by using a 719-719 patch lead.
  • 712-719 4 pins Male to Female Patch Lead
  • Available in a variety of lengths:
  • 50cm
  • 100cm
  • 150cm
  • 1 x 712-719 Male to Female 4 Pin Patch Lead
  • 50cm
  • 100cm
  • 150cm
