Gå til produktinformasjon
1 av 4
Aim ACC 3 Open Analogue CAN Converter
SKU: ACC-Open-2
£250.00
£300.00
INC VAT - UK only
£250.00
£250.00
£300.00
INC VAT - UK only
£250.00
Please note - OPEN devices must be programmed in Race Studio 3 via USB to enable them to transmit data on none preset CAN ID's
logo The compact AiM Analogue CAN Converter
ENHANCE YOUR LOGGER PERFORMANCE ACC 3 is the new compact and powerful Analogue CAN Converter that manages up to four channels at 200 Hz each. Now compatible also with the AiM Solo 2 DL.
ACC 3 - Analogue CAN Converter
  • Analogue channels: 4 fully configurable channels, 24 bit, A/D, 200 Hz each: TC (with dedicated cable), TR, 0÷5 V, 0÷12 V
  • Speed Inputs: 2 (AN3-AN4), max frequency 10 kHz, internal pull-up for open drain/collector input
  • External power: 9-15 V operational 12-15 V fully operational
  • Connection: CAN
  • Connectors: 2 Binder 712 fem connectors
  • Material: PA6 30% glass
  • Dimensions: 44.0 x 38.0 x 19.8 mm
  • Weight: 50 g
Acc tech sheet
ACC3 Analogue CAN Converter
  • ACC3 Converter
  • CAN cable
  • 4 channels harness
  • Connection: CAN
  • Weight: 50 g
Acc tech sheet
  • ACC3 Converter
  • CAN cable
