Gå til produktinformasjon
1 av 1
Aim DTA S60 Motorcycle Interface Lead MXL Evo
SKU: ECU-DTA-MC
£80.00
£80.00
+ MVA (kun Storbritannia)
Powered by Shopify Planet
Aim DTA S60 Interface Lead for MXL EVO
Aim DTA S60 Interface Lead for MXL EVO allows you to easily connect your ECU to our high tech data logger and is highly engineered.
Aim DTA S60 Motorcycle Interface Lead MXL Evo is one of the specially developed applications for many of the most popular ECUs. By special applications, we mean user-friendly systems which allow you to easily connect your ECU to our high tech data logger. You only need to install a harness between the logger and the ECU.
Once connected, the logger displays (and/or records depending on the logger on the ECU data stream and configuration) values like RPM, engine load, throttle position (TPS), air and water temperatures, battery voltage, speed, gear, lambda value (air/fuel ratio) analogue channels
