AiM MXP 1.3 6" TFT World SSP600 FIM Kit
SKU: MXP-FIM-600-X012KC6ZK
- £2,190.00
- £2,190.00
AiM MXP 6" TFT World SSP600 FIM Kit
The MXP dash logger has a 6" TFT display which has been designed to acquire and display data coming from the ECU.
6" TFT display | GPS Module included |
Integrated shift array | 37 pin harness |
AiM has designed a specific connection cable for the World SSP 600 bikes.
The 37 pins Deutsch harness can read transmitted data from the ECU via CAN and power up the system.
This kit is compatible with:
World SSP 600 Bikes (with MecTronic) - MKE7 ECU) 2019/2020
Please see the technical sheet for the information on the Sumitomo connection kit, which also includes the information regarding the pinout and Race Studio 3 configuration.
It shows a vast amount of protocols, Channel Name & Function for Mectronik WSS 2019 V5.
AiM MXP 6" TFT
The MXP TFT 6" comprehensive colour Dash Logger is fully configurable and suitable for many different Motorsports. It has been designed to acquire and display data coming from the ECU. The internal accelerometer and GYRO, GPS Module (included in the kit), analogue/digital inputs and predefined math channels. Performance and data acquired can also be incremented by adding up to eight expansion modules.
Connecting the MXP dash to your ECU is simple. You can sample dozens of channels straight from the vehicle ECU. This is usually the quickest and easiest setup, needing only a cable connection to the ECU instead of multiple connections and analogue sensors. The sampled data will depend on your actual ECU but typically includes RPM, engine load, throttle position (TPS), oil, air, water temperature, oil pressure, battery voltage, speed, gear, lambda value (air/fuel ratio). The list of available ECU drivers is constantly updated and upgraded and includes approximately 1000+ different ECUs.
Two Digital Outputs
MXP features two digital outputs. Each of them can give an output of 1 amp at 12 volts. They can be configured to be turned on/off depending on the value of the analogue or digital inputs. They permit automatically running external systems such as switching on/off additional lights to activate/deactivate a cooling fan or circulation pumps when a particular event happens.
The MXP has a high contrast 6" TFT display which is fully configurable. You can create and customise pages/displays to suit your requirements. You can manage to swap pages by pushing one or two pushbuttons.
Two analogue camera inputs are available to switch your display into a mirror camera through a pushbutton command or event management. The camera is sold separately.
Flexible Alarms
The MXP has ten configurable RGB LEDs. You can choose the conditions and colours. Select a solid alarm or flashing one and the flashing frequency. You can choose to have an accompanying text message and set the alarm priorities.
With integrated shift lights, you can choose from a host of advanced multi-coloured RGB shift light patterns that You can customise to suit your requirements and each unique gear when required.
CAN output
GPS Module
The GPS Module connected via CAN to the MXG makes lap time calculation and track position analysis easy. With 4000+ worldwide tracks already stored with start and finish line coordinates, you will have no problem when you're on track. As soon as the MXP is turned on, the GPS Module will locate its position, identify track line coordinates and start immediately sampling lap and split time. If the track is not on the database, you can easily add the start/finish line coordinates to the MXP via a PC before going to the track using our Race Studio 3 software.
The GPS Module is available with this kit 1.3m or 2m fairing mount.
- Display: 6" TFT Display
- Contrast: 600:1
- Ambient Light Sensor: Yes
- CAN connections: 3
- Second CAN: Yes
- Body: Anodized Aluminium
- Power Consumption: 400mA
- Weight: 640g
- MXP 1.2 Dash Logger
- 37 pins harness
- GPS Module
- Connection Kit
- 1 x 6 pins male Sumitomo connector
- 4 x Sumitomo connector male pins
- 4 x rubber wire seals
- 2 x dummy plugs
The MXP dash logger has a 6" TFT display which has been designed to acquire and display data coming from the ECU.Key Features :
AiM has designed a specific connection cable for the World SSP 600 bikes.The 37 pins Deutsch harness can read transmitted data from the ECU via CAN and power up the system.
World SSP 600 Bikes (with MecTronic) - MKE7 ECU) 2019/2020Please see the technical sheet for the information on the Sumitomo connection kit, which also includes the information regarding the pinout and Race Studio 3 configuration.
AiM MXP 6" TFT
The MXP TFT 6" comprehensive colour Dash Logger is fully configurable and suitable for many different Motorsports. It has been designed to acquire and display data coming from the ECU. The internal accelerometer and GYRO, GPS Module (included in the kit), analogue/digital inputs and predefined math channels. Performance and data acquired can also be incremented by adding up to eight expansion modules.Easy Connection
Two Digital Outputs
MXP features two digital outputs. Each of them can give an output of 1 amp at 12 volts. They can be configured to be turned on/off depending on the value of the analogue or digital inputs. They permit automatically running external systems such as switching on/off additional lights to activate/deactivate a cooling fan or circulation pumps when a particular event happens.Display
The MXP has a high contrast 6" TFT display which is fully configurable. You can create and customise pages/displays to suit your requirements. You can manage to swap pages by pushing one or two pushbuttons.Two analogue camera inputs are available to switch your display into a mirror camera through a pushbutton command or event management. The camera is sold separately.
Flexible Alarms
The MXP has ten configurable RGB LEDs. You can choose the conditions and colours. Select a solid alarm or flashing one and the flashing frequency. You can choose to have an accompanying text message and set the alarm priorities.With integrated shift lights, you can choose from a host of advanced multi-coloured RGB shift light patterns that You can customise to suit your requirements and each unique gear when required.
CAN output
The GPS Module connected via CAN to the MXG makes lap time calculation and track position analysis easy. With 4000+ worldwide tracks already stored with start and finish line coordinates, you will have no problem when you're on track. As soon as the MXP is turned on, the GPS Module will locate its position, identify track line coordinates and start immediately sampling lap and split time. If the track is not on the database, you can easily add the start/finish line coordinates to the MXP via a PC before going to the track using our Race Studio 3 software.The GPS Module is available with this kit 1.3m or 2m fairing mount.
With Race Studio 3 you can also analyse all data recorded by MXP and downloaded to your PC: graphs, histograms and tables will help you study your performance, providing objective support to avoid mistakes and improve performances. ![]() |
- Contrast: 600:1
- Second CAN: Yes
- Weight: 640g
- 37 pins harness
- GPS Module
- Connection Kit
- 2 x dummy plugs
