Gå til produktinformasjon
1 av 3
Aim MXP 1.3 6" TFT Suzuki Logger with CAN Connection
SKU: MXP-SUZ-KIT
£2,190.00
£2,628.00
INC VAT - UK only
£2,190.00
£2,190.00
£2,628.00
INC VAT - UK only
£2,190.00
AiM MXP Suzuki Logger with CAN Connection
The MXP Suzuki dash logger has a 6" TFT display which has been designed to acquire and display data coming from the ECU.
6" TFT display GPS Module
CAN output 10 configurable RGB LEDs shift lights
Connecting the MXP dash to your ECU is simple. You can sample dozens of channels straight from the vehicles ECU. This is usually the quickest and easiest setup, needing only a cable connection to the ECU instead of multiple connections and analogue sensors. The sampled data will depend on your actual ECU but typically includes RPM, engine load, throttle position (TPS), oil, air, water temperature, oil pressure, battery voltage, speed, gear, lambda value (air/fuel ratio). The list of available ECU drivers is constantly updated and upgraded and includes approximately 1000+ different  ECUs.
Two Digital Outputs
Flexible Alarms
CAN output
GPS Module
Pin Harness
  • Display: 6" TFT Display
  • CAN connections: 3
  • ECU connection: CAN, RS232 or K-Line to 1,000+ industry-leading ECUs
  • Second CAN: Yes
  • Wi-Fi connection: Yes
    + 3 axis magnetometer
  • Internal Memory: 4 GB
  • Body: Anodized Aluminium
  • Pushbuttons: Metallic
  • Power Consumption: 400mA
  • Weight: 640g
  • MXP Dash Logger
  • 37 Pin standard harness
  • GPS Module with cable
The MXP TFT 6" wide colour Dash Logger is fully configurable and suitable for many different Motorsports. It has been designed to acquire and display data coming from the ECU. The internal accelerometer and GYRO, GPS Module (included in the kit), analogue/digital inputs and predefined math channels. Performance and data acquired can also be incremented by adding up to eight expansion modules.   Easy Connection
Two Digital Outputs
With a high contrast 6" TFT display which is fully configurable. You can create and customise pages/displays to suit your requirements. Swapping pages can be managed by pushing on or two pushbuttons. Two analogue camera inputs are available, to switch your display into a mirror camera, through a pushbutton command or event management. The camera sold separately.
Flexible Alarms
The MXP has ten configurable RGB LEDs. You can choose the conditions and colours. Select a solid alarm or flashing one and the flashing frequency, you can choose to have an accompanying text message and set the alarm priorities. With integrated shift lights you can choose from a host of advanced multi-coloured RGB shift light patterns that can be customised to suit your requirements, and for each unique gear when required.
CAN output
GPS Module
The GPS Module connected via CAN to the MXG makes lap time calculation and track position analysis easy. With 4000+ worldwide tracks already stored with the start and finish line coordinates you will have no problem when you're on the track. As soon as the MXP is turned on the GPS Module will locate its position, identify track line coordinates and start immediately sampling lap and split time. If the track is not on the database, you can easily add the start/finish line coordinates to the MXP via a PC before you go to the track using our Race Studio 3 software. The GPS Module is available in 1.3m or a roof version in 2m.
Pin Harness
  • Second CAN: Yes
  • Weight: 640g
  • MXP Dash Logger
