AiM MXP 1.3 Strada Suzuki IVA Compliant 6" TFT Display Plug & Play Kit
SKU: MXP-S-SUZ-KIT
- £1,075.00
- £1,075.00
6" TFT display | Road legal & MOT approved |
CAN output | Configure data |
The dash comes with a 23 pin loom which has pre-configured connections for all the relevant electrical items in your vehicle such as oil. temperature, engine temperature, fuel level, sidelights, hazards, front and rear fog, handbrake, main beam, dipped beam and left and right-hand indicator. A speed sensor is also included in the kit to connect to this additional loom.
Digital Outputs
Pre-configured Pages
Flexible Shift Light & Alarms
Camera Inputs
- Display: 6" TFT
- Contrast: 600:1
- Ambient Light Sensor: Yes
- Alarm Display Icons: Yes, fully configurable
- Alarm LEDs: 5 integrated freely configurable RGB LEDs
- CAN Connections: 3
- Second CAN: Yes
- Body: Anodized Aluminium
- Power Consumption: 400 mA
- Dimensions: 189.6 X 106.4 X 24.9mm
- Weight: 590g
- MXP Strada
- USB Cable
- 23 IVA Loom
- Wheel Speed Sensor
The MXP Strada IVA compliant digital dash display is a complete road legal display solution.Key Features :
The MXP Strada features a 6" wide colour TFT display, offering a fantastic visual impact. It is configurable to show data coming from the ECU, nine axes inertial platform (accelerometer, GYRO and magnetometer). Eight analogue inputs, six digital inputs, pre-defined math channels, a second CAN and an optional GPS Module.Easy Connection
Connecting the MXP Strada dash to your ECU is simple. You can sample and display dozens of channels straight from the vehicle ECU. This is usually the quickest and easiest setup, needing only 2 cable connections to the ECU instead of multiple connections to analogue sensors.The dash comes with a 23 pin loom which has pre-configured connections for all the relevant electrical items in your vehicle such as oil. temperature, engine temperature, fuel level, sidelights, hazards, front and rear fog, handbrake, main beam, dipped beam and left and right-hand indicator. A speed sensor is also included in the kit to connect to this additional loom.
Digital Outputs
The MXP features two digital outputs. The two digital outputs (Dout) are the LOW SIDE type (switch to ground). They can be configured in order to be turned on/off depending on the value of the analogue or digital inputs. They permit to automatically run external systems. For example, switch on/off additional lights, to activate/deactivate a cooling fan or circulation pumps when a certain event happens.With CAN Output you can send messages directly to an existing CAN network to improve the range of vehicle control possibilities.
The MXP has a 6" high contrast TFT display. The visual quality is kept optimised by the ambient light sensor which keeps the backlight to its best brightness levels, so as to avoid the screen dazzling you while driving in the dark.Pre-configured Pages
The MXP Strada shows the RPM scale and all the data you need, like speed, water temperature and oil pressure, lap times and much more. You can custom pages to suit your requirements, including up to four additional fields. Define what data is shown with the end of scale and measure units. Swapping between the pages is easy just use the pushbuttons.Flexible Shift Light & Alarms
The ten multi-coloured RGB shift lights can be customized to your liking, defining the RPM threshold on analogue or digital inputs, ECU values, expansion values, math channels or optional GPS options. You can choose the conditions and colours, select a solid arm or flashing one, also the flashing frequency. You can also configure an accompanying text message and set the alarm priorities.Camera Inputs
With Race Studio 3 you can also analyse all data recorded by MXP Strada and downloaded to your PC: graphs, histograms and tables will help you study your performance, providing an objective support to avoid mistakes and improve performances. ![]() |
- Display: 6" TFT
- Contrast: 600:1
- Second CAN: Yes
- Weight: 590g
- MXP Strada
- USB Cable
- 23 IVA Loom
