Gå til produktinformasjon
1 av 3
AiM MyChron5 Temperature Sensor 712-719 3 Pin Patch Lead
SKU: P-712-719-15-3
£40.00
£40.00
+ MVA (kun Storbritannia)
Powered by Shopify Planet
The AiM 712-719 MyChron5 temperature sensor 712-719 3 pin patch lead.
712-719 patch lead 3 pin male to female
High-quality connectors Suitable for MyChron
The AiM temperature sensor 712-719 patch lead has a four-pin female connector and a three-pin male connector. AIM Motorsport sensor for use with all MyChron kart dash/data loggers (including the new MyChron5 S and the older generation MyChron4).
Designed to perform in challenging motorsport environments
Ideal to have as a spare
Suitable for AIM Motorsport kart temperatures sensors
Cable Length - 1500mm
  • MyChron5 712-719 3 pin Patch Lead
  • Metallic male Binder 3 pin
  • Plastic female Binder Connector 4 pin
  • Length: 1500mm
  • 1 x 712-719 Temperature Sensor 3 pin Patch Lead
  • Length: 1500mm
