Gå til produktinformasjon
1 av 3
Aim SmartyCam Mini Roll Cage Mount
SKU: SM-VB-S
£50.00
£60.00
INC VAT - UK only
£50.00
£50.00
£60.00
INC VAT - UK only
£50.00
The SmartyCam HD, Sport or Corsa can be installed using the HD roll cage mount. It is suitable for the SmartyCam 2.1, 2.2 & 3.
Fits the SmartyCam 2.1, 2.2 & 3 camera
Universal roll bar fitment
Standard or extended length
SmartyCam HD Compatible
SmartyCam 3 Sport Compatible
SmartyCam 3 Corsa Compatible
The Aim mini roll bar mounts have been designed to fit the SmartyCam camera, and enable it to easily be mounted to a roll bar tube.
The mount is manufactured from aluminium with a black anodised finish and designed to withstand the rigours of motorsport use.
Provides an easy method of mounting the SmartyCam to a roll bar.
The supplied jubilee drive clips allow for fitting two different roll cage tube diameters.
Standard or extended lengths are available to choose from.
For use with SmartyCam HD, Sport & Corsa (2.1, 2.2 & 3).
  • Roll cage mount (standard or extended version) One supplied
  • 2 x Jubilee clips
The Aim mini roll bar mounts have been designed to fit the SmartyCam camera, and enable it to easily be mounted to a roll bar tube. The mount is manufactured from aluminium with a black anodised finish and designed to withstand the rigours of motorsport use.
  • 2 x Jubilee clips
