Kawasaki Plug & Play Aim Taipan Motocross ECU Kit
SKU: C-EUC-KIT-KAW
- £635.00
- £635.00
AiM Taipan ECU Plug & Play Kit For Kawasaki Motocross Bikes
Taipan is the brand-new aftermarket plug & play ECU created by AiM, exclusively designed for off-road bikes. Thanks to its high technology 32-bit core, it represents an important step forward to improve the performance of your bike, without sacrificing reliability and smoothness.
Injection main alpha-n | Injection main speed-density |
Injection crank correction | Pre-injection |
Injection BAP Correction | Injection EWT Correction |
Injection IAT Correction | Injector Battery Correction |
Injector 2 | Ignition BAP Correction |
Ignition EWT Correction | Ignition IAT Correction |
Ignition Opening Transient Correction | Ignition Closing Transient Correction |
Launch Control | Injection Launch Control Main Table |
Ignition Launch Control Main Table | Quick Shift |
Traction Control |
Traction Control Strategy
Launch Control
High Technology 32-bit Core
Engine control requires precision. At 20,000 RPM the Taipan ECU guarantees a precision of 1/10 of degree: this means an accuracy within 0.8 sec for turning the spark ON!
UC Bridge
Tuner License :
Taipan ECU Connections
Aim Handlebar Switch
AiM Taipan ECU Plug & Play Kit for Kawasaki
- Two 0-5V analogue inputs sampled @ 1,000 Hz each, could be alternatively used as a switch to ground
- Second injector driver for high impedance saturated injectors (12Ω)
- One low side driver (1 A)
- Two CAN Bus, one for calibration purposes, one for expansions - (AiM handlebar switch, dataloggers, dash etc
- Three JST JWPF waterproof auxiliary connector
- Power consumption 150 mA
- Connectors: n. 1 JST 04T-JWPF-VSLE-S Connector
- n. 1 JST 08R-JWPF-VSLE-D Connector
- n. 1 JST 04R-JWPF-VSLE-S Connector
- n. 1 33 pin male Connector
- Body: PA6 + 30% glass fiber
- Dimensions: 89.4 x 75.4 x 29.3mm
- Weight: 260g
- Plug & Play ECU for Kawasaki
Taipan is the brand-new aftermarket plug & play ECU created by AiM, exclusively designed for off-road bikes. Thanks to its high technology 32-bit core, it represents an important step forward to improve the performance of your bike, without sacrificing reliability and smoothness.It provides the ultimate control in feeling, ignition, ignition phase, start maps, launch control, traction control with altitude and engine temperature corrections.
Traction Control |
For each map, the ECU has a dedicated traction control main table.Launch Control
For each map, the ECU has a dedicated launch control main table.High Technology 32-bit Core
UC Bridge
Tuner License : With this license, the tuner can create different maps, configurations and strategies designed for the rider's bike. The tuner can then flash them directly onto the ECU or send them via email to allow the rider to download and install them in the ECU.
- Weight: 260g
Video
