BMW S1000RR & S1000RR HP4 AiM EVO4S Logger Plug & Play Cable
SKU: BMW-PP-EVO
- £67.00
- £67.00
+ MVA (kun Storbritannia)
BMW S1000RR & S1000RR HP4 AiM EVO4S Plug & Play Cable
The AiM ECU plug & play cable has been specifically designed for BMW bikes. Allowing easy installation to an EVO4S Data Logger. With a 7-pin 712 male binder connection.
BMW plug & play cable | 7 pin - 712 male binder connection |
Receive data | Suitable for EVO4S |
BMW Plug & Play ECU Cable
The AiM ECU plug & play cable has been specifically designed for the BMW bike. This plug & play cable can be used for the EVO4S.
The plug & play cable currently fits the following BMW bike models:
S1000RR - 2009-2014 | S1000RR - From 2015 |
S1000RR HP4 - 2013-2014 |
Example data protocols
- Below is a pinout drawing for the BMW EVO4S plug & play connection cable
- BMW S1000RR, S1000RR HP4 Plug & Play connection cable
The AiM ECU plug & play cable has been specifically designed for BMW bikes. Allowing easy installation to an EVO4S Data Logger. With a 7-pin 712 male binder connection.Key Features :
The AiM ECU plug & play cable has been specifically designed for the BMW bike. This plug & play cable can be used for the EVO4S.The cable is an easy fitment to your bike and allows ECU data to be logged.
The plug & play cable currently fits the following BMW bike models:S1000RR - 2009-2014 | S1000RR - From 2015 |
