Gå til produktinformasjon
1 av 12
Deutsch Male & Female DTM Plug & Pins including Wedge Lock
SKU: P-DTM-2-F
£8.00
£8.00
The Deutsch male & Female DTM Plug & Pins, including wedge lock, are ideal connectors for PDM use and are often used in engine compartments and transmission tunnels.
Male & Female DTM plugs Pins & wedge lock
2 to 12 way options
The plug & pins are suited for applications that require a secure & reliable connector in harsh environments, like under the hood of your car, transmission tunnels and other areas that need secure connections in both power and signal.
  • Tactile and audible connector mating
  • Rugged thermoplastic connector housing
  • Hand insertable/removable connects
  • Operating temperature range: -55 to +125°C
  • Positive contact retention
  • 1 x DTM Deutsch plug, pins, wedge lock
2 to 12 way options
