Gå til produktinformasjon
1 av 4
Ducati Panigale V4/V2 Euro5 AiM Solo 2 DL Plug & Play Lap Timer Kit
SKU: SOLO2-K-DUC-EURO5
£710.00
£710.00
AiM Solo 2 DL is the most precise and simple way to get lap times. Specifically designed for the Ducati this kit will ensure an improvement in your driving performance.
Database with more than 4,000 tracks worldwide Ducati Panigale ECU connection cable
This kit has been specifically designed for Ducati Panigale bikes. The kit comes with a cable and bracket for your bike. Connecting the Solo 2 DL to your Ducati Panigale ECU will give you all the engine performance information you need to help improve your driving performance.
The plug & play cable currently fits the following Ducati Panigale bike models:
Panigale Euro5 V4 - From 2018 Panigale Euro5 V2 - From 2020
The Ducati Panigale ECU interface cable provides a plug & play solution for connecting the Solo 2 DL lap timmer to your bike. Please refer to the technical sheet on how to connect the ECU cable to your bike.
Data Recall On Screen
  • Display: Graphical
  • Wi-Fi connection: Yes
  • GPS: 10 Hz
  • External power: 12 V
  • Memory: 4 GB
  • Pushbuttons: Metallic
  • Waterproof: IP67
Below is the pinout drawing for the Ducati Panigale V4/V2 plug & play connection cable.
Ducati Panigale V4/V2 AiM Solo 2 DL Plug & Play Lap Timer Kit
  • Solo 2 DL
  • Power cable with AC adapter
  • User manual
  • AiM Ducati Panigale V4/V2 Connection Cable
  • Bracket
  • 1 washer
  • 1 rubber dowel
The Ducati Panigale ECU interface cable provides a plug & play solution for connecting the Solo 2 DL lap timmer to your bike. Please refer to the technical sheet on how to connect the ECU cable to your bike. The sampled data you record depends on the actual ECU but typically includes RPM, engine load, throttle position (TPS), oil, air, water temperature, oil pressure, battery voltage, speed, gear and lambda value (air/fuel). The list of ECUs is forever growing and being updated. Add a SmartyCam HD/GP HD camera to create an even more powerful system to help provide you with great videos that include all the technical information to help improve your performance. Solo 2 DL gives instant speed, timing splits live data and predictive lap times. The Solo 2 DL has a sharp, high contrast display which helps drivers easily identify the data displayed on the screen. The Solo 2 DL also features a selection of 7 different backlight colours which can be selected to suit your requirements. Please Note: For these models/years Aim recommends not to remove the stock dash. Doing so will disable some of the bike functions or safety controls.
  • GPS: 10 Hz
  • Memory: 4 GB
  • Waterproof: IP67
  • Solo 2 DL
  • User manual
  • Bracket
  • 1 washer
  • 1 rubber dowel
