Gå til produktinformasjon
1 av 1
GASGAS Plug & Play AiM Taipan Motocross ECU Kit for Linkpop
SKU: C-ECU-KIT-GG-XE1ECUHBSUCB0
£635.00
£635.00
+ MVA (kun Storbritannia)
Powered by Shopify Planet
AiM Taipan ECU Plug & Play Kit For GASGAS Motocross Bikes
Traction Control
Traction Control Strategy
Launch Control
High Technology 32-bit Core
Engine control requires precision. At 20,000 RPM the Taipan ECU guarantees a precision of 1/10 of degree: this means an accuracy within 0.8 usec for turning the spark ON!
UC Bridge - Optional Extra
Tuner License :
*Please Note: For information regarding the UC-Bridge Tuner, Please contact one of our Aim technical team for further information.
Taipan ECU Connections
Below shows a functional diagram of products that can be added to the Taipan ECU:
AiM Taipan ECU Plug & Play Kit for GASGAS
  • One low side driver (1 A)
  • Power consumption 150 mA
  • n. 1 33 pin male Connector
  • Body: PA6 + 30% glass fiber
  • Waterproof: IP67
  • Weight: 260g
  • Plug & Play ECU for GASGAS
Traction Control
Launch Control
Tuner License :
  • Waterproof: IP67
  • Weight: 260g
Video
