Gå til produktinformasjon
1 av 2
Ducati Panigale V4/V2 AiM EVO4S Logger Plug & Play Cable
SKU: DUC-PP-EVO
£67.00
£67.00
+ MVA (kun Storbritannia)
Powered by Shopify Planet
Ducati Panigale V4/V2 AiM EVO4S Plug & Play Cable
The AiM ECU plug & play cable has been specifically designed for Ducati Panigale V4/V2 bikes. Allowing easy installation to an EVO4S Data Logger. With a 7-pin 712 male binder connection.
Ducati Panigale V4/V2 plug & play cable 7 pin - 712 male binder connection
Receive data Suitable for EVO4S
Ducati Panigale V4/V2 Plug & Play ECU Cable
The AiM ECU plug & play cable has been specifically designed for the Ducati Panigale V4/V2 bike. This plug & play cable can be used for the EVO4S Data Logger.
The plug & play cable currently fits the following Ducati Panigale bike models:
Panigale V4 - From 2018 Panigale V2 - From 2020
Example data protocols
  • Below is a pinout drawing for the Ducati Panigale V4/V2 plug & play connection cable
  • Ducati Panigale V4/V2 Plug & Play connection cable
