Gå til produktinformasjon
1 av 4
Kawasaki ZX-10R AiM Solo 2 DL Plug & Play Lap Timer Kit
SKU: SOLO2-K-KAW
£717.00
£717.00
AiM Solo 2 DL is the most precise and simple way to get lap times. Specifically designed for the Kawasaki this kit will ensure an improvement in your driving performance.
Database with more than 4,000 tracks worldwide Kawasaki ECU connection cable
This kit has been specifically designed for Kawaski bikes. The kit comes with a cable and bracket for your bike. Connecting the Solo 2 DL to your Kawaski ECU will give you all the engine performance information you need to help improve your driving performance.
The plug & play cable currently fits the following Kawasaki bike models:
Kawasaki Ninja ZX-10R MY2011 - 2011-2015 Kawasaki Ninja ZX-10R MY2011 Racing Kit - 2011-2015
Kawasaki Ninja ZX-10R MY2016 - From 2016 Kawasaki Ninja ZX-10R MY2016 Racing Kit - From 2016
Please Note: The bracket fits Kawasaki models from 2016.
The Kawasaki ECU interface cable provides a plug & play solution for connecting the Solo 2 DL lap timmer to your bike. Please refer to the technical sheet on how to connect the ECU cable to your bike.
Data Recall On Screen
  • Display: Graphical
  • Wi-Fi connection: Yes
  • GPS: 10 Hz
  • External power: 12 V
  • Memory: 4 GB
  • Pushbuttons: Metallic
  • Waterproof: IP67
Below is the pinout drawing for the Kawasaki plug & play connection cable.
  • Solo 2 DL
  • Power cable with AC adapter
  • User manual
  • AiM Kawasaki Connection Cable
  • Bracket
  • 2 toothed washers
  • 2 Allen screws M6 x 12mm
The Kawasaki ECU interface cable provides a plug & play solution for connecting the Solo 2 DL lap timmer to your bike. Please refer to the technical sheet on how to connect the ECU cable to your bike. The sampled data you record depends on the actual ECU but typically includes RPM, engine load, throttle position (TPS), oil, air, water temperature, oil pressure, battery voltage, speed, gear and lambda value (air/fuel). The list of ECUs is forever growing and being updated. Add a SmartyCam HD/GP HD camera to create an even more powerful system to help provide you with great videos that include all the technical information to help improve your performance. Solo 2 DL gives instant speed, timing splits live data and predictive lap times. The Solo 2 DL has a sharp, high contrast display which helps drivers easily identify the data displayed on the screen. The Solo 2 DL also features a selection of 7 different backlight colours which can be selected to suit your requirements. Please Note: For these models/years Aim recommends not to remove the stock dash. Doing so will disable some of the bike functions or safety controls.
  • GPS: 10 Hz
  • Memory: 4 GB
  • Waterproof: IP67
  • Solo 2 DL
  • User manual
  • Bracket
  • 2 toothed washers
