Link Mitsubishi EVOLink - EVO9X PlugIn ECU
SKU: EVO9X
- £1,475.00
- £1,475.00
This ECU is designed for the EVO 9 4G63 engine.
Includes onboard 4 bar or 7 bar MAP sensor
Suitable Applications:
CT9A Lancer Evolution 9, 2005-2007
CT9A Lancer Evolution 8, 2003-2005 with 3 plug ECU ONLY
Any EVO8 car with a 3 plug ECU will also require this ECU.
PlugIn Key Features:
Sequential fuel delivery
OEM idle hardware supported
CAN port
USB tuning cable included
Staged injection
Knock with "windowing"
I/O Expansion Options:
Expansion connector 1
Gnd Sensor Ground Only
DI 9 Digital Input
DI 10 Digital Input
Aux 11 Auxiliary Output
An Volt 11 Analog 0-5V input
An Volt 8 Analog 0-5V input
Expansion connector 2
Aux 9 EThrottle - can't be used as an Aux out
Aux 10 Auxiliary Output
An Volt 6 Analog 0-5V input
An Volt 7 Analog 0-5V input
An Volt 9 Analog 0-5V input
An Volt 10 Analog 0-5V input
- G4X PlugIn ECU
- Stickers
CT9A Lancer Evolution 9, 2005-2007CT9A Lancer Evolution 8, 2003-2005 with 3 plug ECU ONLY
CAN port
Staged injection
The following expansion connector inputs/outputs are provided:Expansion connector 1 Gnd Sensor Ground Only
DI 9 Digital Input
DI 10 Digital Input
An Temp 4 Temperature sensor input Expansion connector 2 Gnd Sensor Ground Only
- G4X PlugIn ECU
- Stickers
