Link Mazda RX7Link (S7) - RX7S7X PlugIn ECU
SKU: RX7S7X
- £1,145.00
- £1,145.00
Designed for the RX7 series 7-8 13BT.
Suitable Applications:
FD3S Series 7 RX7
FD3S Series 8 RX7
This ECU will support naturally aspirated, parallel twin or single turbo configurations. Does not support sequential control of the stock twin turbos.
Sequential fuel delivery
OEM idle hardware supported
CAN port
USB tuning cable included
Staged injection
Knock with "windowing"
I/O Expansion Options:
Expansion connector 1
Gnd Sensor Ground Only
DI8 Digital Input
DI7 Digital Input
An Volt 5 Analog 0-5V input
An Volt 6 Analog 0-5V input
An Volt 7 Analog 0-5V input
Expansion connector 2
Ign 5 Ignition 5 Auxiliary Output
An Volt 9 Analog 0-5V input
An Volt 8 Analog 0-5V input
DI10 Digital Input
DI9 Digital Input
- G4X PlugIn ECU
- Stickers
FD3S Series 7 RX7FD3S Series 8 RX7
CAN port
Staged injection
The following expansion connector inputs/outputs are provided:Expansion connector 1
DI8 Digital Input
DI7 Digital Input
DI10 Digital Input
DI9 Digital Input
- G4X PlugIn ECU
- Stickers
