Link Nissan S13Link - NS13X PlugIn ECU
SKU: NS13X
- £1,325.00
- £1,325.00
Designed for the SR20 and CA18 engines, that use the 76 pin Blue ECU Header.
It includes an onboard 4 bar or 7 bar MAP sensor.
Suitable Applications:
Nissan S13 CA18DET
Nissan 180SX CA18DET
Nissan S14 (pre-facelift) SR20DET
PlugIn Key Features:
Sequential fuel delivery
OEM idle hardware supported
CAN port
USB tuning cable included
Staged injection
Knock with "windowing"
I/O Expansion Options:
Expansion connector 1
Gnd Sensor Ground Only
DI 5 Digital Input
DI 6 Digital Input
DI 7 Digital Input
An Volt 6 Analog 0-5V input
Expansion connector 2
Ign 5 Ignition 5 Auxiliary Output
Volt 8 Analog 0-5V input
Volt 9 Analog 0-5V input
Volt 10 Analog 0-5V input
Volt 11 Analog 0-5V input
Link Nissan S13Link - NS13X ECU
- G4X PlugIn ECU
- Stickers
Nissan S13 CA18DETNissan 180SX CA18DET
CAN port
Staged injection
The following expansion connector inputs/outputs are provided:Expansion connector 1
DI 5 Digital Input
DI 6 Digital Input
DI 7 Digital Input
- G4X PlugIn ECU
- Stickers
